Quick cap question...
Username: Kicker101
Alberta
Post Number: 190
okay before i hear it ill just say that yea i know a capacitor wont cure the lack of voltage/power or whatever...but i do plan on getting a new alternator aswell...
so with that being said...on to my question. Will it be fine if i use a cap rated higher than my amp? for ex. i have a 1600 watt amp. can i use say 2.0 farad? or do i have to stick with 1.6 farad? i dont have any experience with them so any help would be great! P.S. I do plan on getting a 20volt or higher and not a 16volt.
Username: Oneracistguy
TWO EGG, FL USA
Post Number: 818
try batcaps
www.batcap.net
Username: Skibum12189
Cleveland
Post Number: 1055
if you get a new alternator and a new battery, you should have NOOO problems with 1600 watt amp...
Cleveland
Post Number: 1056
"for ex. i have a 1600 watt amp. can i use say 2.0 farad?"
o wait, didnt know that was an example ahah sorry, umm but idk the answer to tell you the truth
but hey bump for some guys who know more than me!!
Username: B3n07
the cap would be perfect becauce you know the amps getting its power
Username: Loudon
Post Number: 1425
also depends on ur amplifier ...
im running a 1500d sundown with a yellowtop and big 3... if ur amp if efficent there should be no problem ...
Username: Kicker101
Alberta
Post Number: 191
haha thanks guys so bottom line im am gettin a 2.5 farad cap for my 1600 watt amp. that will have plenty of quick juice to feed the amp although that being said the cap will only ever have 1600 watts of juice in it right?
Username: B3n07
Louisville, Ky USA
Post Number: 12
no there will be 2500 watts of juice in it just think of the cap as a bank or a resever which saves energy and relases it as you need it
Username: Kicker101
Alberta
Post Number: 192
k cool bud but it will do the job with out any problems right?
Username: B3n07
Louisville, Ky USA
Post Number: 15
yeah it will work 4 ya no problem
Username: Kicker101
Alberta
Post Number: 193
k one other stupid question that i think i have asked before so sorry if i did...but i need to know if you can hook up a 1/0 guage power wire to it(Hifonics BXI1606d) and run 10 guage speaker/sub wire from it?
i lookd at the specs and stuff but it just says 4 guage terminals... take a look for me or let me knoe if you have it...
its the Hifonics
BXI1606dhttp://www.maxxsonics.com/hifonics/amps_brutus.html
http://cgi.ebay.ca/Hifonics-BXi1606D-1-Channel-Amplifier-MonoBlock-Car-Amp_W0QQi temZ290072735770QQihZ019QQcategoryZ64570QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
Cleveland
Post Number: 1082
ehh, when i had mine, i had 1/0 to a distro, 4 gauge to my 1206, 4 gauge to my zx350, and 4 gauge to the cap, all grounded to the same place..
i have that distro for sale if ya need it
Username: Kicker101
Alberta
Post Number: 194
so u cant use a 1/0 guage with out a disribution block?
Username: Kicker101
Alberta
Post Number: 195
okay so im gonna use 1/0 guage and then a distblock to a 4 guage(same with the ground) but i also have a cap so should i do the distro block before or after the cap?????
Username: Kicker101
Alberta
Post Number: 196
sorry but bump
Username: Kpa2727
Post Number: 356
hell farads don't mean a hell of alot just don'tgo over 5 cause the discharge to charge rate goes down to where it'd not worth a dime. i run on a 600 rms infinity and i'm running a 5.0 farad tsunami cap. farads only matter when u decide to go to large.
Username: Kicker101
Alberta
Post Number: 197
yeah i am just gonna do what i said above but..should i put the distro block before or after the cap and should? and if anyone has this amp can u please tell me what the biggest speaker/sub wire u can use? will 10 guage fit?
thanks...
Username: Kpa2727
Post Number: 361
idk i'd go after the distro that way ur at the amp. cause it's suppose to be very close to the amp to work correctly.
Username: B3n07
Louisville, Ky USA
Post Number: 21
ok put the cap in front of everything ok this is what your wiring should be set up
wire from battery to cap
from cap to distrubutor
from distrubutor to amp
Username: Kicker101
Alberta
Post Number: 198
is it okay if i use a 2 guage power wire and a 1/0 guage ground?
for ex. 2 guage power wire to the amp, 2 guage ground wire from the amp, 1/0 guage ground wire from the capacitor and 1/0 guage ground from the battery.....???
Username: Kicker101
Alberta
Post Number: 200
any one?
Username: Van_man
Boston South, MA
Post Number: 2687
As a guide, 1 fared per 1000 watts.
And yes, bigger ground wire is fine to use.
Username: Kicker101
Alberta
Post Number: 201
thanks
