New member Username: Mark872Post Number: 1 Registered: Jul-07 | would anyone know if a Super Bass Probox would be a good box for two 12 alpine type X's...the box i have them in now is a small alpine ported box that the type S's came in a long ago |
Platinum Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 12605 Registered: Jul-05 | build ur own box |
Platinum Member Username: BestmankindITS ALL ABOUT THE RL-S Post Number: 14487 Registered: Oct-05 | well its a SUPER box so it should be good. naw but seriously, what are the specs of that box? |
New member Username: Mark872Post Number: 2 Registered: Jul-07 | L-36" W-22.5" H-14" 2.25 cu. ft per side |
Platinum Member Username: BestmankindITS ALL ABOUT THE RL-S Post Number: 14489 Registered: Oct-05 | is it ported? also if its a sealed box i'd just build it myself. it shouldn't be that hard. the type x sounds good in small sealed so a slight bigger box isn't going to be too much of an improvement. |
Gold Member Username: Tremor1127Team Fi Car Audio [:-] Post Number: 2021 Registered: Aug-06 | there are very few subs built that are reccommended to NOT be used in ported boxes... type X is one. but, with that said, the super pro bass boxes arent bad but they arent good. ive played with different ones and they worked well... |
New member Username: Mark872Post Number: 4 Registered: Jul-07 | well the box i have them in now is a box that was made for the type S's...so anythin will prolly be better than what i got..i just want a box to put them to ther max. potential |
New member Username: Mark872Post Number: 5 Registered: Jul-07 | and yes chad its ported |
Gold Member Username: JakeyplaysbassSt. Louis, MO Post Number: 1864 Registered: Jul-05 | go for a small sealed box. |
New member Username: Mark872Post Number: 6 Registered: Jul-07 | ive heard them in a sealed box before and they sounded terrible..what a about a MDF box tuned at 32Hz? Heres a link of it http://cgi.ebay.com/DUAL-12-CUSTOM-PORTED-MDF-SUB-ENCLOSURE-4-0FT-3-32Hz_W0QQite mZ150135880877QQihZ005QQcategoryZ50566QQtcZphotoQQcmdZViewItem |
