Silver Member Username: Aaronjp1990Lerwick, Shetland Uk Post Number: 125 Registered: Apr-06 | i just bought a set of 165v2 focal polyglass was wondering how they sound and how good out of 10 they are? |
Gold Member Username: The_image_dynamicSan Diego Post Number: 2434 Registered: Dec-06 | They sound great but the highs are a bit harsh, but I like that in a car environment with all the other noise. 7.5/10 |
Silver Member Username: Thumpinwith8s2 RE8s, 300 watt Jense..., 133.3db@49hz!! Post Number: 456 Registered: Jun-07 | Aaron, just wondering,,,,why would you buy something THEN ask how good it is? Its usually done the other way around |
Silver Member Username: JtownPost Number: 165 Registered: Mar-07 | lol.....even funnier: watchin that fat@ss sean kingsten sing that lame song on fuse right now... |
Silver Member Username: Aaronjp1990Lerwick, Shetland Uk Post Number: 126 Registered: Apr-06 | haha good point well i was in the shop and wanted to finish my system of so i bought them. i live on a island and was of it for a week. but i have run in to the problem that they dont fit haha so am thinking about making a box to put them in any ideas on that? |
Gold Member Username: The_image_dynamicSan Diego Post Number: 2435 Registered: Dec-06 | They dont fit where? In the doors? And why won't they fit? There are ways around that. |
Silver Member Username: Aaronjp1990Lerwick, Shetland Uk Post Number: 127 Registered: Apr-06 | my stock ones are 13 but that not the prob. they go into the dash and the magnet is bringing up in the wiper motor on the passengers side so i need about 25-30mm of mdf sticking to clear it. and theres not enough room to mold it with fiber glass so i was thinking about making 2 box's to mount between the seats or above the headrests. any other ideas? |
Gold Member Username: The_image_dynamicSan Diego Post Number: 2438 Registered: Dec-06 | Make rings out of mdf and use that as a spacer to get to the (lack of) depth you need. Or maybe try to move the mount on the wiper motor a little down? Comps are generally designed to sound good in an infinite baffle setup and won't sound all that great in a small box. |
Silver Member Username: Aaronjp1990Lerwick, Shetland Uk Post Number: 128 Registered: Apr-06 | ill try that out next week will elt u kno how it goes |
Silver Member Username: JtownPost Number: 166 Registered: Mar-07 | if that doesn't work, you should mount them inside your center console, assuming you have some sort of compact car. so that they serve the same purpose as the speakers in the doors, cept now the driver and passenger have sound coming from both left and right directly at them....maybe? |
Silver Member Username: Aaronjp1990Lerwick, Shetland Uk Post Number: 129 Registered: Apr-06 | dont have a center concole. this is the best pic i can find on the net of my interior. its the new modle tho http://www.carpages.co.uk/land_rover/land-rover-defender-review-part-5-05-02-05. asp |
