Skilled box builders
Username: Matt12490
California USA
Post Number: 2554
Hey can anyone design me a box for my 2 RE SE 10s. I don't want to use the 'freeportedboxplans.com' or whatever that website is because it is giving me some messed up plans. Anyways, I want a 2.5 net cubed box slot ported tuned to 30hz. My max dimensions are 31" wide and 16.5" high. Can anyone help me here? I'll paypal you $5.
Username: Insearchofbass
Post Number: 5777
sure but I dont have paypal
Post Number: 5778
ill do the golden ratio if it can fit
Username: Freezeman_7
C.FREE
Post Number: 1600
talk to logan. he has built boxes for SE's before
also talk to ogle.
Post Number: 5779
ill do it for free just remember me when I need ya lol
Post Number: 5780
whats the max depth
Username: Matt12490
California USA
Post Number: 2555
25"
Post Number: 5781
ok figuring out your port
Username: Matt12490
California USA
Post Number: 2556
You're fast
Thanks sean
Username: Johnfiac
A-ToWn, 9515 thumpin... What u bumpin?
Post Number: 3353
if you could find out how much port area they like i can get u some plans
Username: Johnfiac
Post Number: 3354
also... port and subs firing to rear or did u have somthing else in mind
Post Number: 5782
how much power are you going to be running?
SQ = SoundSplinter RL-s
Post Number: 14281
when i saw the title of this thread i was thinkig hey that's me. lol.
unfortunately i am also a lazy one so i can't do that for you. lol.
Username: Matt12490
California USA
Post Number: 2557
I'll remember that chad :'(
I'm giving them 600rms each subs and port firing to the rear. Not sure how much port area they need, but the SEs have 18mm xmax. Could help a bit. I'm off to work right now I'll be back a lil later.
Thanks guys
Post Number: 14282
just playin man.
when i go home i'll think of something. i got all the links and helpful info in my laptop at home. in the meantime if someone came up with what you like then thats fine also.
Post Number: 5783
im gonna do 39 square inches that will be a .05 vent mach
Post Number: 5784
whats the sub displacement otherwise ill estimate
Post Number: 5785
ok does it have to be slot ports cuz you ran out of room
Post Number: 5786
wait im fixing it
Username: Jkidder
Spring hill, Florida Usa
Post Number: 1118
sean, do you have AIM? IM me if u do - JK32SHO
Post Number: 5787
no sorry I got to go
Post Number: 5788
I was almost done but heres the golden ratio for 2.60 cubic feet (internal measurements 16.5 deep x 13 high x 21 wide) you would need mre width though to fit the 10's side by side
Username: Oglejust
Post Number: 2410
sean... i believe the tread was refering to me jm lol
Username: Matt12490
California USA
Post Number: 2558
.14 per sub displacement.
