Username: Bigharv Post Number: 107 Registered: Jun-07
Tuesday, July 17, 2007 - 21:27 GMT If i upload a sine wave onto my ipod and play it through my head unit will that work fine for setting the gain or will the ipod distort the signal because it has its own amplification? its a direct RCA connection to the head unit
Username: Tiki89 Post Number: 157 Registered: Oct-06
Tuesday, July 17, 2007 - 23:27 GMT F^CK OFF!!!!!!!
Username: Blainew Post Number: 2392 Registered: Nov-05
Wednesday, July 18, 2007 - 01:34 GMT dont play it through the ipod...try to get the tone on a cd or u can just set the gain by knowing your output voltage of your HU, and knowing the input sensitivity range of your amp
Username: Tejcurrent Post Number: 75 Registered: Apr-07
Wednesday, July 18, 2007 - 02:42 GMT ^^ knowing your voltage helps, but I'd use a test cd unless it skips too bad to set with cd. take it to a shop where they can use an oscilliscope.
