Silver Member Username: Kingandsons07Lincoln, Nebraska U.S.A Post Number: 142 Registered: Feb-07 | IDC about price. i got one BTL. |
Platinum Member Username: BestmankindSQ = SoundSplinter RL-s Post Number: 14270 Registered: Oct-05 | what ohm is the sub? |
Silver Member Username: Kingandsons07Lincoln, Nebraska U.S.A Post Number: 143 Registered: Feb-07 | O yeah my bad 1ohm |
Gold Member Username: Tremor1127Team Fi Car Audio [:-] Post Number: 1923 Registered: Aug-06 | dual 1 ohm coils? |
Silver Member Username: Kingandsons07Lincoln, Nebraska U.S.A Post Number: 144 Registered: Feb-07 | yep |
Gold Member Username: JblanfordPost Number: 1971 Registered: Oct-06 | sundown saz-3000d |
Gold Member Username: Th3pwn3rPost Number:... Post Number: 3694 Registered: Jul-06 | Quentin I hate to ask but you do have the charging for that type of amp right? |
Gold Member Username: Tremor1127Team Fi Car Audio [:-] Post Number: 1927 Registered: Aug-06 | "sundown saz-3000d" x2 or an amp from here, i believe any of AB amps, especially the VFL series, that are rated at 1 ohm will also do .5 ohm daily. http://www.americanbassusa.com/amps.html |
Gold Member Username: Tremor1127Team Fi Car Audio [:-] Post Number: 1928 Registered: Aug-06 | were you wanting to run ALOT of watts or RMS? |
Silver Member Username: Kingandsons07Lincoln, Nebraska U.S.A Post Number: 145 Registered: Feb-07 | what do you mean?? |
Gold Member Username: JblanfordPost Number: 1972 Registered: Oct-06 | how is your charging system ? |
Silver Member Username: Kingandsons07Lincoln, Nebraska U.S.A Post Number: 146 Registered: Feb-07 | i wont to run ALOT of watts for Daily |
Gold Member Username: JblanfordPost Number: 1974 Registered: Oct-06 | well do you already have the charging system to support "ALOT of watts for Daily" ? |
Silver Member Username: Kingandsons07Lincoln, Nebraska U.S.A Post Number: 147 Registered: Feb-07 | IDK Stock ford explorer |
Silver Member Username: Kingandsons07Lincoln, Nebraska U.S.A Post Number: 148 Registered: Feb-07 | what do i need??? |
Gold Member Username: Tremor1127Team Fi Car Audio [:-] Post Number: 1933 Registered: Aug-06 | yeah, you can "get away" with it up to about 2000 watts but you still have a chance of doing damage. 3000-4000 watts you need HEALTHY charging. no BS... 300 amp alt. minimum mandatory and 1 or 2 deep cycle batteries minimum mandatory, as well. |
Gold Member Username: 04redmach1Columbus, GA USA Post Number: 1086 Registered: Mar-06 | Naw, that won't do it. Your going to need a HO alt, big battery, and upgraded wires. Can you afford that? Shoot me an email if interested in the SAZ-3000D, but you will have to upgrade charging before running it. Kevin lowhz01@yahoo.com |
Gold Member Username: Tremor1127Team Fi Car Audio [:-] Post Number: 1934 Registered: Aug-06 | mayyybe 250 and up amp alternator. there are 300-400 amp alts though. powermaster alts. |
Gold Member Username: Tremor1127Team Fi Car Audio [:-] Post Number: 1935 Registered: Aug-06 | the SAZ-3000D has gotta be a beast... |
Silver Member Username: Kingandsons07Lincoln, Nebraska U.S.A Post Number: 149 Registered: Feb-07 | ok right on how much for that amp??? |
Gold Member Username: JblanfordPost Number: 1975 Registered: Oct-06 | email kevin above... They retail for 1099 though |
Silver Member Username: Kingandsons07Lincoln, Nebraska U.S.A Post Number: 150 Registered: Feb-07 | it's been done |
Gold Member Username: JkidderSpring hill, Florida Usa Post Number: 1099 Registered: Nov-05 | rd audio 5750 at 2 ohm puts out about 2800. can u afford that? |
Bronze Member Username: Chuck78Post Number: 76 Registered: Mar-07 | you will also need to set aside about $1000 for charging system upgrades.... |
Gold Member Username: 420alldaylongPost Number: 2303 Registered: Sep-06 | Kicker ZX2500.1 |
Silver Member Username: Kingandsons07Lincoln, Nebraska U.S.A Post Number: 151 Registered: Feb-07 | here my old stuff |
