Silver Member Username: Jester_kingPost Number: 320 Registered: Apr-07 | well I will have about 250$'s tomarrow and I need help choosing a sub, I want excellent sq with good output, needs to be tight and accurate, I listen to rock and have alot of space to work with, I am currently looking at Atomic manhatten 15", IDQ 15" and RD classic 15", any suggestions are appriciated, thank you |
Gold Member Username: Th3pwn3rPost Number:... Post Number: 3711 Registered: Jul-06 | It seems like you've already made up your mind.Get the IDQ so you can tell me how great it sounds. |
Silver Member Username: FearthisskyyDallas, Texas United states Post Number: 301 Registered: Apr-07 | be sure to check out idmax and fi q too |
Silver Member Username: Jester_kingPost Number: 321 Registered: Apr-07 | well I have been hearing great things about the IDQ and MAX but the max is alot of cash, I'm not really into Fi but have looked, I'm not sure how good the brand is but elemental designs I've been looking at, but thanks for the opinions |
Silver Member Username: FearthisskyyDallas, Texas United states Post Number: 303 Registered: Apr-07 | a used idmax will run in your price range... haven't installed mine yet, but from what i read/researched it should be gooddd for "sql" i would also check out sound splinter's Rl-p, SSA icon, and tc sound's drivers i read that the idq is great for SQ but doesn't have much output at all, and that the id sub has more output than idq |
Silver Member Username: Jester_kingPost Number: 322 Registered: Apr-07 | like I'm not looking to be the loudest person, I just want a good bump and for it to be tight accurate bass that can keep up with fast beats, as long as I can hit 135-140DB's with 2 15" IDQ's then that would be plenty loud for me |
Silver Member Username: FearthisskyyDallas, Texas United states Post Number: 304 Registered: Apr-07 | i didn't know you were going to get two, two 15" of anything listed should get loud enough for ya, just go for whatever sounds best then lol |
Gold Member Username: 420alldaylongPost Number: 2304 Registered: Sep-06 | Not sure on prices but check out the RD elite. http://www.rdaudio.net/woofers/elite.php |
Silver Member Username: Jester_kingPost Number: 323 Registered: Apr-07 | yeah I do plan on getting 2 eventually but for right now I'm going with 1, I have been checking out RD's stuff and it all looks really nice |
