Gold Member Username: OglejustPost Number: 2309 Registered: Aug-06 | 2 12inch Fi SSD's in a 5 cuft box tuned 33 hz Hifonics 2006 at 1 ohm the other box is for his friends 2 12inch type r's, its 3.7 cubes 34 hz. |
Gold Member Username: 54danny54KY More Wang Th... Post Number: 3915 Registered: Nov-04 | not bad ball jogle'er lol |
Gold Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 8434 Registered: Jun-06 | Yes Yes Yes Muthafuka!!!!!!! |
Silver Member Username: Philly306North carolina Post Number: 114 Registered: Apr-07 | WOW |
Gold Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 8436 Registered: Jun-06 | |
Platinum Member Username: BestmankindSQ = SoundSplinter RL-s Post Number: 14192 Registered: Oct-05 | looking good. very clean install. the box is sick. you da man. www.justinogleisthebest.com |
Gold Member Username: Logan__tilleI walk around like I g..., Yea thats ab... Half a brick... Post Number: 8513 Registered: Feb-06 | Whos Cody? |
Gold Member Username: OglejustPost Number: 2312 Registered: Aug-06 | NVmyBOOm |
Gold Member Username: Safe_crackerChicago, IL US Post Number: 3035 Registered: Jan-06 | What a waste of room! If I had all that space it would be filled, lmfao.. |
Gold Member Username: OglejustPost Number: 2313 Registered: Aug-06 | haha yeah he shouldve gotten 15's |
Gold Member Username: Safe_crackerChicago, IL US Post Number: 3037 Registered: Jan-06 | 4x18's |
Gold Member Username: Nyyfan13Fi SSD USA Post Number: 5480 Registered: Jul-06 | why didnt he get 15's? anyway, good sh!t cody and ogle.... |
Gold Member Username: OglejustPost Number: 2314 Registered: Aug-06 | haha polo ur crazy he wanted 2 12's i guess lol |
Silver Member Username: Wolf_houndPost Number: 419 Registered: Sep-05 | Nice, looks awesome |
Gold Member Username: OglejustPost Number: 2321 Registered: Aug-06 | ^^ i no |
Platinum Member Username: Rovin4 10 Pioneer... Post Number: 11801 Registered: Jul-05 | looks good but dont keep that amp on the box ...... |
Gold Member Username: OglejustPost Number: 2322 Registered: Aug-06 | i put cardboard behind it its fine |
Platinum Member Username: Rovin4 10 Pioneer... Post Number: 11804 Registered: Jul-05 | ok - but when u learn the hard way remember Rovin told u so ....... |
Gold Member Username: OglejustPost Number: 2323 Registered: Aug-06 | lol its fine... theres plenty of padding behind it |
Silver Member Username: NvmyboomPost Number: 256 Registered: Jul-06 | i got 12's cause their cheaper, and require alot less power to run, which results in less money spent. plus, i will enjoy blowin away all the trashy 15's that are around these parts anways... |
Silver Member Username: TatonkaPost Number: 543 Registered: Mar-07 | "i got 12's cause their cheaper, and require alot less power to run" A SSD 15" is $20 more than a 12. They both have the same rms. I guess u saved $40 lol :D I know those have to sound good. I installed one of them on a hifonics 1206D, it was great. |
Silver Member Username: NvmyboomPost Number: 260 Registered: Jul-06 | ya i love them already, but im very happy with these twelves, ....i still need a HO alt though |
Silver Member Username: NvmyboomPost Number: 261 Registered: Jul-06 | o, flatwind coils to |
Gold Member Username: Safe_crackerChicago, IL US Post Number: 3041 Registered: Jan-06 | "lol its fine... theres plenty of padding behind it" I learned this flying helicopters, adding a dampening material no matter what it is does not make it stop vibrate but moves the rate at which it vibrates either up/down. The best thing is not to vibrate at all, the energy has to go somewhere but it doesn't have to be in your amp, get it? Polo.. |
Bronze Member Username: Vt_aholeUSA Post Number: 57 Registered: Jun-07 | looks real nice. good work whats wrong with putting the amp right on the box? |
Gold Member Username: SplmonsterC-Town, OH USA Post Number: 1353 Registered: May-06 | it will possibly eventually rattle somethin loose |
Gold Member Username: OglejustPost Number: 2326 Registered: Aug-06 | the point of the padding is to disipate vibrations |
Silver Member Username: NvmyboomPost Number: 276 Registered: Jul-06 | im lookin to get some rubber to put between my box and amp, any idea where i could get a solid piece??? |
Gold Member Username: OglejustPost Number: 2360 Registered: Aug-06 | just use a bicycle intertube |
Silver Member Username: CriedErie, PA US Post Number: 548 Registered: Jun-07 | I used about 1/2 or 5/8" thick rubber washers so the amp sat off the box. It provided for better ventilation as well as little to zero vibrations. |
