Are these numbers decent enough to power 2 4ohm dvc Kicker Cvx 12s.
A two channel amp.
2 x 600 Watts RMS at 4 Ohms 2 x 1200 Watts Max at 4 Ohms 1 x 2400 Watts Max at 4 Ohms Bridged 2 x 1000 Watts at 2 Ohms RMS Electronic Crossover Network Bass Boost Circuit Variable Phase Shift Control 2 Ohms Stereo Stable Anti-Thump Turn-On Soft Turn On/Off High & Low Level Inputs Blue Light Illuminated Crossover Control Power & Protection LED Indicators Advanced Protection Circuitry Bass Boost Remote Control T.H.D: 0.04% S/N Ratio: 90dB Channel Separation: 65dB Frequency Response: 15Hz- 35kHz Dimensions: 10.47"W x 2.46"H x 19"L
I didn't put the brand because i'm not interested in whether someone thinks it's crap and i should spend more. I'll upgrade the quality later.
That Lanzar 252 realistically pushes around 600RMS bridged @ 4 ohms so you're looking at 300 per sub. Not the worst amp in the world.... wire the subs like this and you'll be fine until you upgrade.
couldn't i just wire each sub parallel instead so each channel is seing a 2 om instead. Or would it just be better to get the more powerful lanzar. This one says 2 x 1000 rms @2ohms, now i know it won't put out quite that much, but couldn't i at least get 500 or so to each sub at 2ohm.
The reason why I said to run it in mono is because that amp will not run two subs at 2ohms each. Lanzar is very vague about their specs and what they mean by 2 x 1000RMS @ 2ohms is the TOTAL load, 4ohms per side. Configuring it like I recommended above is your only option and it will sound fine until you upgrade.
