Username: N1nja Post Number: 1 Registered: Jul-07
Wednesday, July 11, 2007 - 01:56 GMT Will a 4 channel 2000W(4X500w) amp power 1 alpine type-r sub? I dont know anything about amps sorry, any help would be appreciated...
Username: Logan__tille I walk around like I g...,
Yea thats ab...
Half a brick...
Post Number: 8501 Registered: Feb-06
Wednesday, July 11, 2007 - 02:21 GMT What brand amp?
Username: N1nja Post Number: 2 Registered: Jul-07
Wednesday, July 11, 2007 - 04:26 GMT its Mitzu...
Username: N1nja Post Number: 3 Registered: Jul-07
Wednesday, July 11, 2007 - 05:44 GMT Can a 4ch 2000w amp be wired to give all 2000W to the sub? Or is it only possible for it to give the sub 500W? I don't really know what I'm talking about, i just don't want to underpower my sub.
Username: Tejcurrent Post Number: 57 Registered: Apr-07
Wednesday, July 11, 2007 - 14:55 GMT I wouldn't do it. Can you bridge the channels into 2 channels? If so put one coil per bridged set, but I'd just get a mono amp.
Username: N1nja Post Number: 5 Registered: Jul-07
Wednesday, July 11, 2007 - 15:48 GMT problem is, i already bought the amp on ebay like a dumbass. But yes, 2 channels are bridgeable, so it is possible to give all 2000W to my sub?
Username: Tejcurrent Post Number: 59 Registered: Apr-07
Thursday, July 12, 2007 - 04:30 GMT it depends on what ohm load the coils are, and at what ohm the amp puts out rated power. what vc configuration is it?
Username: N1nja Post Number: 6 Registered: Jul-07
Thursday, July 12, 2007 - 05:43 GMT Nevermind, I decided screw it, i just bought a mono 2000W amp, thanks for the help though i appreciate it.
Username: Juliob Santo DomingoDominican Re...
Post Number: 4782 Registered: Dec-05
Thursday, July 12, 2007 - 17:28 GMT what brand? Mitzu really s.cks You should get a jl 500/1
Username: N2audio Lawrence,
Ks
Post Number: 1354 Registered: Mar-04
Thursday, July 12, 2007 - 18:38 GMT That 2000w mitzu is probably closer to 500w - maybe less. What mono amp did you buy? Is the sub model number end in 42 or 22?
Username: Its_bacon12 Hfl,
Ny
Usa
Post Number: 1231 Registered: Dec-03
Friday, July 13, 2007 - 15:37 GMT no you will not get all the power. you will get half of whatever the real RMS power is, which is likely to be about 1/6 to 1/4 the power they say it is. its a piece of junk. they say its 2000 watts which is peak power and is extremely misleading, the RMS power is the true continuous output the speaker will actually see. FYI peak power is a marketing trick, makes the amp look 4-5x more powerful than it is. you'd be lucky if that thing is 75w rms x4
Post Number: 4794 Registered: Dec-05
Friday, July 13, 2007 - 22:08 GMT haha that mitzu comes with a 20A fuse, i'm telling you cuz i got scammed once
