Finally got on a TL
Username: Yamahabanshee1
Paulding, Ohio USA
Post Number: 410
I did a 144.3 at 48hz and a 143.8 playing lil jon- da blow. this was windows up and all
Username: 54danny54
KY More Wang Th...
Post Number: 3888
whats your system
A pic is worth 1000 posts!!
Post Number: 8360
Info pleeze!
Paulding, Ohio USA
Post Number: 411
1 15" memphis mojo dual 2ohm in a 6.0cuft box tuned to 38hz. Optima Red Top, Kinetik HC800 in the back, big 3 done. Memphis 16-mc1000D at 1ohm. Pioneer 6800mp head unit. in a ext cab sonoma
Username: 420alldaylong
Post Number: 2244
Sweet
Paulding, Ohio USA
Post Number: 412
ya i was pretty pleased with that number! it was also very hot! so hopefully i can do a lil better at the comp on the 21st
Username: Safe_cracker
Chicago, IL US
Post Number: 3017
Is 48hz where it peaked? Quite a bit higher than your box tuning...Polo. :-)
Username: Insearchofbass
Post Number: 5642
its probably his resonant frequency..... were ported at 35 hz and peak at 54 hz to 55 hz depending
Post Number: 5643
56 hz low volume
Username: Basssquared
Kansas
Post Number: 957
i think tunning at 38 HZ is the sweet spot
Paulding, Ohio USA
Post Number: 413
yes 48hz is where i peaked!
Username: Oglejust
Post Number: 2259
48hz still isnt really high. good score man. btw y not try a little bit littler box? try like 4 cubes, u might be suprized
Username: Jblanford
Post Number: 1888
"little bit littler box?"
only from you ogle...only from you lol
Kansas
Post Number: 963
i love that amp man it really gives out a lot of power for the price
