OT head unit not working
Username: Mercsable
Kalamazoo, MI USA
Post Number: 138
I just bought a pioneer deh-p5900ib and it plays cds just fine, except none of the buttons work. I can change the volume but I cant switch to the next track or change the source. any ideas?
Username: Sqlspl
Derby, CT
Post Number: 23
I know it is simple enough but is the face locking in correctly. I had a problem with my Clarion not locking. I fixed the mechanism and it has not given me a problem since. If thats not it than maybe it is the connection from the face to the unit itself. Not sure. I am sure one of the more knowledgeable gentlemen will help you. I enjoy Pioneer head units. Excellent sound production.
Username: Kpa2727
Post Number: 331
check the contacts that press against the flip face on the inside and just bend them a little bit to make contact. keep in mind i'm not rliable for your actions but that should fix it.
Username: Mercsable
Kalamazoo, MI USA
Post Number: 139
Well I pressed in the face plate a little and got it working for a second but now it doesnt work again. Im sure the problem is that its not making contact but what can I do to fix that? what part are you talking about that I should bend?
Username: Logan__tille
We dont drink PepsiWe just sell...
Post Number: 8548
lol I the same problem with my deh-p6400, excepet I always had to have my finger pressed against it or I couldnt see sh!t.
Post Number: 8549
So I just bought a new face plate.
Username: Mercsable
Kalamazoo, MI USA
Post Number: 140
well i just bought this so I dont want to have to go and get a new face plate already. If I need to though, where can I get one
Username: Extrmndor3
IF U HEAR ME... crazydbs.com
Post Number: 6145
i have a headunit for sale :-)
Username: Thumpinwith8s
2 RE8s, 300 watt Jense..., 133.3db@49hz!!
Post Number: 406
if you just bought it, and bought it new from a shop/store, you should be able to take it back and do an exchange
Username: Mercsable
Kalamazoo, MI USA
Post Number: 141
no thanks, I just bought a brand new one took it out of the box and it doesnt work properly. I get to adjust the volume and thats it
Post Number: 407
thats why I said, take it back and exchange it for another of the same one, you may have just got a defective unit
