Scrambled or bad channel on 2700 a pansat
Username: Abcdefghijklmnop
Post Number: 22
can someone help me with this problem i did boot b-75 upgrade on my pansat 2700A after that it worked for a couple of days and now its been three weeks and i am getting scrambled and bad channel ? anyone any help
Username: Eatfish111
Post Number: 347
did you also updat with the 203 bin file when you did the b-75 upgrade?
if not do it
if yes then reset factory defaults and set your sats again.
Or do a hard reboot from the back turn receiver off with the switch in the back wait 30 seconds then turn back on.
Username: Micklee11801
Post Number: 114
makesure autoroll is on too.
Username: Lroy
Post Number: 222
This can be fixed by ensuring that the box is flashed with a working bin, have all your settings correct and then, go to menu, parental control, second pin, enter code (0000), then go to set default key and press OK. After that exit and allow keys to roll (if an AR bin was used, or else enter keys manually), enjoy TV again.
Post Number: 23
thank you guys it worked i put the bin 203 and then turned auto roll on and wallah
thanks again for ur help
