Silver Member Username: PhuktupbassheadPhoenix, Arizona United State... Post Number: 675 Registered: May-05 | Can anyone refer me to a website or kick me down some information regarding the Eclipse by Fujitsu Ten (8712.4)? I appreciate it. thanks. |
Gold Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 8209 Registered: Jun-06 | How old is it? I can't locate that number on at least this site. http://www.fujitsu-ten.co.jp/english/product/modelnumber/index.html |
Silver Member Username: PhuktupbassheadPhoenix, Arizona United State... Post Number: 677 Registered: May-05 | How old it is... I have no idea... I bought it mounted in a box. But the back of the sub looks brand spanking new. The stickers are still intact very nicely, etc. But, from the scarcity of the info on it - it MUST be old, right? Please keep trying... I've had NO luck at all!!! |
Gold Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 8222 Registered: Jun-06 | Finding some more for ya. http://www.howardforums.com/archive/topic/707571-1.html |
Silver Member Username: PhuktupbassheadPhoenix, Arizona United State... Post Number: 678 Registered: May-05 | Thanks, Paul! That helps... I didn't know they had a "bottomless" design. Cool. All I need now is the recommended sealed/ported enclosure dimensions. Wierd how it's so hard to find, huh? I wish I knew the value of the sub too. Think it's a little more valuable now that it's a rare find?? |
Gold Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 8223 Registered: Jun-06 | Same guy, same sub. A little more info including Vas and Xmax ect. Should be enough. http://www.torontoaccords.com/forums/viewtopic.php?t=33019&view=next&sid=cebafb4 f722e33dd6e26d8a1445e1dfd |
Gold Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 8224 Registered: Jun-06 | |
Silver Member Username: PhuktupbassheadPhoenix, Arizona United State... Post Number: 681 Registered: May-05 | Paul Larrea: Thank you very much! As always, you are a very helpful member of ecoustics. Keep up the good work!!! (If there's any other information you can find on it - let me know. Is it an SQ, SQL, or SPL sub? etc, etc...) |
Gold Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 8287 Registered: Jun-06 | Well golly pilgram, you're just gonna have to find that one out for yourself lol. It's your sub, you tell us how it sounds. How did you come across buying a sub you knew nothing about? J/W. |
