Gold Member Username: 420alldaylongPost Number: 2232 Registered: Sep-06 | A friend needs a 500-600RMS Mono amp 1ohm or 2ohm stable. It will be for two Memphis PR 15" 250RMS each. No more than $200 must be new ideas please. Thanks |
Silver Member Username: Gavbo211JL Audio 10w3v2, IL US Post Number: 552 Registered: Jan-05 | If you can find it for under 200 (try ebay).. Phoenix Gold X600.1 would be awesome. those amps are solid as hell. |
Silver Member Username: Gavbo211JL Audio 10w3v2, IL US Post Number: 553 Registered: Jan-05 | oh. "must be new". didn't catch that.. well that rules out my pick. |
Platinum Member Username: BestmankindSQ = SoundSplinter RL-s Post Number: 14137 Registered: Oct-05 | you can get a autotek ss500.1 for under 200 bux brand new. |
Gold Member Username: 420alldaylongPost Number: 2234 Registered: Sep-06 | Help |
Silver Member Username: Mike11202Sewell, NJ US Post Number: 794 Registered: Nov-06 | this one should work perfect http://cgi.ebay.com/JBL-GTO601-1-600-WATT-GRAND-TOURING-MONO-CAR-AMPLIFIER_W0QQi temZ320134799773QQihZ011QQcategoryZ64570QQssPageNameZWDVWQQrdZ1QQcmdZViewItem |
Bronze Member Username: BigharvPost Number: 37 Registered: Jun-07 | I got the Phoenix Gold Xenon 600.1 for $190 shipped never used in box off some guy on CA.com phoenix gold amp's are badass and well worth the money |
Platinum Member Username: BestmankindSQ = SoundSplinter RL-s Post Number: 14140 Registered: Oct-05 | http://cgi.ebay.com/AUTOTEK-SS500-1-1-4-CHANNEL-AMP-500-WATTS-SS500-NEW_W0QQitem Z230122075537QQihZ013QQcategoryZ39732QQrdZ1QQssPageNameZWD1VQQcmdZViewItem this amp is good. my friend just bought one couple of weeks ago and its a little beast. if you don't want to buy from ebay then send me the money and i can go get one for you. i can get it for $120 and charge you 20 bux for shipping. so its $140 for a brand new amp from a store. cheaper than ebay. |
Bronze Member Username: BigharvPost Number: 38 Registered: Jun-07 | what amp chad? |
Gold Member Username: CtmikeCt. Post Number: 4783 Registered: Feb-06 | just a guess, but i think the amp chad is talking about might be the one in the link he posted. i'm thinking if you clicked the link, the blue underlined letters and whatnot, you might see the amp, not sure though. just a guess |
Bronze Member Username: BigharvPost Number: 39 Registered: Jun-07 | lol no link is showing up on my screen sorry to ask such a dumb question i guess |
Gold Member Username: CtmikeCt. Post Number: 4784 Registered: Feb-06 | ebay item #230122075537. |
Platinum Member Username: BestmankindSQ = SoundSplinter RL-s Post Number: 14142 Registered: Oct-05 | lol www.ctmikeisthebest.com |
Gold Member Username: 04redmach1Columbus, GA USA Post Number: 1026 Registered: Mar-06 | I have a Massive Audio P500.1 or .2. One is 1 ohm and other is 2 ohm stable. $200 shipped and you will get it next day. Kevin |
Platinum Member Username: BestmankindSQ = SoundSplinter RL-s Post Number: 14144 Registered: Oct-05 | damn that is fast shipping. you can't beat that. i'd take kevin's deal. |
Gold Member Username: 420alldaylongPost Number: 2236 Registered: Sep-06 | This lucky SOB got a kicker KX600.1 for $150 used but he knows the guy the amp is in very good condition. Thanks for you guys help. END THREAD |
