Silver Member Username: Loc_outSanta Ana, Ca Resonant Eng... Post Number: 879 Registered: Feb-05 | Okay my bro bought this comp last year but never got the chance to install them. I am going to install them in my truck but need an amp. Can you guys suggest some amp? there 90RMS |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 4772 Registered: Dec-05 | grab a 4 channel, a kicker 350.4 |
Silver Member Username: Loc_outSanta Ana, Ca Resonant Eng... Post Number: 880 Registered: Feb-05 | How good are the diamond audio??? Would you consider them better than kicker? http://cgi.ebay.com/DIAMOND-AUDIO-D3400-4_W0QQitemZ290136223741QQihZ019QQcategor yZ39739QQssPageNameZWDVWQQrdZ1QQcmdZViewItem |
Gold Member Username: CarguyPost Number: 6350 Registered: Nov-04 | That's a nice amp. If you can get it cheap, go for it. |
Silver Member Username: Loc_outSanta Ana, Ca Resonant Eng... Post Number: 881 Registered: Feb-05 | There's a buy now option for $130. I saw an xtant that i might try to bit on Isaac or other let me know what you think. here is the link. http://cgi.ebay.com/xtant-404m-4ch-50watts-x-4-sounds-great_W0QQitemZ26013665233 5QQihZ016QQcategoryZ39739QQssPageNameZWDVWQQrdZ1QQcmdZViewItem |
Silver Member Username: Loc_outSanta Ana, Ca Resonant Eng... Post Number: 883 Registered: Feb-05 | There's a buy now option for $130. I saw an xtant that i might try to bit on Isaac or other let me know what you think. here is the link. http://cgi.ebay.com/xtant-404m-4ch-50watts-x-4-sounds-great_W0QQitemZ26013665233 5QQihZ016QQcategoryZ39739QQssPageNameZWDVWQQrdZ1QQcmdZViewItem |
Silver Member Username: Loc_outSanta Ana, Ca Resonant Eng... Post Number: 884 Registered: Feb-05 | Would this amp work? http://cgi.ebay.com/Precision-Power-PPI2360-Amp-Used-No-Reserve_W0QQitemZ1801377 77285QQihZ008QQcategoryZ39732QQrdZ1QQcmdZViewItem |
Silver Member Username: Loc_outSanta Ana, Ca Resonant Eng... Post Number: 886 Registered: Feb-05 | lil help please would that PPI amp work with the listed comp??? |
