Silver Member Username: TheweaselSteamboat springs, Colorado U.S. of A Post Number: 833 Registered: Mar-06 | i'm trying to keep the box as small as possible, so would it be worse if i reduced the port area from 72" sq in to 52 sq in, or if i reduced the volume from 4 cu ft to 3.6 cu ft? |
Gold Member Username: 54danny54KY More Wang Th... Post Number: 3854 Registered: Nov-04 | it depends on the sub really |
Silver Member Username: TheweaselSteamboat springs, Colorado U.S. of A Post Number: 834 Registered: Mar-06 | 2 12" fi ssd copper coil |
Gold Member Username: 54danny54KY More Wang Th... Post Number: 3855 Registered: Nov-04 | that should work...are you using a slot port? switch to aeroports and your box can be smaller |
Silver Member Username: TheweaselSteamboat springs, Colorado U.S. of A Post Number: 835 Registered: Mar-06 | don't know how to tune aero ports or where to point them in a trunk which should i do, decrease port area or volume? |
Platinum Member Username: Rovin4 10 Pioneer... Post Number: 11777 Registered: Jul-05 | ^^^agreed with dem aeros ...... |
Platinum Member Username: Rovin4 10 Pioneer... Post Number: 11778 Registered: Jul-05 | i would say decrease the port area to save space.... |
Gold Member Username: 54danny54KY More Wang Th... Post Number: 3856 Registered: Nov-04 | rob...hit me up on aim and il design you a box with aero's im sure u have my aim |
Silver Member Username: TheweaselSteamboat springs, Colorado U.S. of A Post Number: 836 Registered: Mar-06 | i don't have aim, i know i'm a low-life |
Gold Member Username: 54danny54KY More Wang Th... Post Number: 3857 Registered: Nov-04 | lol well crap |
Silver Member Username: TheweaselSteamboat springs, Colorado U.S. of A Post Number: 837 Registered: Mar-06 | it can be 32" wide, 16.5" tall and less than 20" deep. tuned to 33 hz and sub displacement for both subs is .28 cu ft total. |
Gold Member Username: 54danny54KY More Wang Th... Post Number: 3858 Registered: Nov-04 | if someone dont post a plan before i do then i should have one tomorrow |
Bronze Member Username: CsuhoNashville, Tn Post Number: 22 Registered: Jun-07 | i 3rd the aero port. they are more effeicent then a slot port hence they can be smaller in area and still flow as much if not more than a slot 1.5x the area or more. use 2 4" aeros 13" long for you box and ur set. make the box 32x15.5x18.5 those are external measurements and it will give u a total volume of 4.25ish after everything(no braces but u could add 1 2x2 and it wouldn't effect anything too much but besides stiffen the box up) that is a box with subs and port all on the same face all firing back. |
Silver Member Username: TheweaselSteamboat springs, Colorado U.S. of A Post Number: 839 Registered: Mar-06 | are you sure that's 4.25 cu ft? before any displacement i come up with 4.2 cu ft. also, how do i adjust the length of the aero ports? |
Bronze Member Username: CsuhoNashville, Tn Post Number: 26 Registered: Jun-07 | would depend on if you made them or bought psp or precsion aero ports. if they were made by some1 like me you can't adjust them since they are a 1 piece port unless you bought just flares and glued couplers on them then you can make them as long as u want. it was 4.21 or so but that .04 wont make a difference. |
Silver Member Username: TheweaselSteamboat springs, Colorado U.S. of A Post Number: 841 Registered: Mar-06 | i plan to buy two 4" aero ports from edesigns. http://www.edesignaudio.com/edv2/product_info.php?cPath=101&products_id=541 so what is the box volume after port displacement? |
Bronze Member Username: CsuhoNashville, Tn Post Number: 27 Registered: Jun-07 | it was 3.75 i believe. |
