latley my amp has been cutting out for a couple seconds then back on. i have a digi amp and i looked at the volt reading and it drops to like 9 and cuts off. i got my alt and battery checkes and there fine. any suggestions. i duno if itis the wiring im using or not.
mrd-1005 yea its stock alt. hasn't been doing it until like 2 weeks ago had it for like 2 years
i think it might be the wiring because i used a cheap brand and i was told all the guages are like half. so i got a 4g and i think its more like an 8g. so i was thinking of doing the big three then doing 0g to the back to the amp then put a little dist. thing on it then put 4g right before it connects
Take a digital multimeter and measure your voltage at the front of the car (at your battery) when the car is playing loud. Is it dropping to 9v up there? If it stays around 14v at the front, but drops to 9 at the back, its a sure bet to upgrade your wire. If its dropping real low up front, upgrade your alt- you might've been slowly killing it.
