Earthquake D10, any one know of it?
Username: Mixmastaspig
Canada, Canada Canada
Post Number: 949
Anyone here run this amp, or know about it?
I think I will be trading either 2 2400.1 Exiles or 1 exile and some cash for the amp.
The D10 is 6000rms @ 2 ohms, and can be burped at .25 ohm for like 9k rms.
Is this something I should be looking into as being a sweet amp? SPL purposes
Username: Nd4spd18
Southeast PA
Post Number: 3067
Earthquake amps suck......... and their subs aren't anything special either.
Post Number: 952
Any more info would be great! As that sounds like a personal opinion rather than a good reason
As a buddy of mine runs the D10 with ONE 12" Sound Stream sub in a little white like, sprint, and hits 152 with a huge Aero port, off the D10, James Chevertte.
(not sure on last name spelling)
http://www.termpro.com/asp/competitorstats.asp?Competitor_ID=42664&Season=2007
He changed his system around, as I was at the show in vernon, June 24th.
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 12521
I would keep the Helix amps...But if ur going to compete I would grab the Earthquake...
Post Number: 953
Yeah, I plan on keeping the Helix, just tossing the Exiles away.
I plan on running the D10 @ 2ohms for 6krms as my subs would most likely die.
Thanks.
