OT - parking brake switch
Username: Boomtank
Rochester, NY USA
Post Number: 316
i just got a flip up indash and was wondering where the parking brake swicth acually hooks too. i have a 98 jeep cheroke sport. i know the bypass code for my unit but need to hook it up to the switch.
Username: Adddisorder
West palm, Florida
Post Number: 4769
that cable i think just needs to hook up to a ground wire. its so you cant watch movies while you drive but that is how you bypass it i think.
Username: Skibum12189
Cleveland
Post Number: 865
eddy hit me on AIM some time caldapaL08
Username: Nd4spd18
Southeast PA
Post Number: 3080
On some units you can just ground that wire and thats the end of it, it thinks the parking brake is always on.
On others it makes you put the brake on and off a few times to unlock the unit....... if yours is like that, you would need to install a switch in the line to ground, so you could flick it on and off to unlock the unit whenever you wanted.
Username: Dakangofkrunk16
Post Number: 661
When i install, flip out, usually grounding it to the HU it self works
If it is jensen, there is code
Username: Boomtank
Rochester, NY USA
Post Number: 317
thx i found the code and it works great.
