Bronze Member Username: Jayroc18Post Number: 18 Registered: Feb-07 | If you had a 99' Honda accord what would you put in the trunk to make yo system sick |
Gold Member Username: Freezeman_7C.FREE Post Number: 1510 Registered: May-06 | talk to chad,he has an accord |
Platinum Member Username: BestmankindSQ IS THE ONLY WAY Post Number: 13948 Registered: Oct-05 | have have a 05 accord and this is what i have in the trunk. soundsplinter rl-s with around 1100-1200wrms. in the pic the box is ported but i just took the port out and put the plug so it sealed. the sq is amazing now. ![]() |
Bronze Member Username: Jayroc18Post Number: 19 Registered: Feb-07 | how long it took for yo sub to come in |
Platinum Member Username: BestmankindSQ IS THE ONLY WAY Post Number: 13951 Registered: Oct-05 | well i am in souther cal and so is soundsplinter. so it came the day after the payment cleared. |
Platinum Member Username: BestmankindSEALED IS THE ONLY WAY Post Number: 13952 Registered: Oct-05 | i bet it will get loud but i am not a fan of mtx subs. don't get me wrong, they are nice. i've heard them but not worth it. you can do so much better. check out companies like soundsplinter....www.soundsplinter.com (buy direct) fi audio.........www.ficaraudio.com (buy direct) rd audio.........www.rdaudio.net (buy from low-hz. they'll hook you up. talk to kevin holden or showrides on this forum) stereo integrity.........http://www.stereointegrity.com/ ((buy from low-hz. they'll hook you up. talk to kevin holden or showrides on this forum)) treo.........www.treoonline.com (call them for a dealer near you) re audio..................www.reaudio.com (buy from low-hz. they'll hook you up. talk to kevin holden or showrides on this forum) atomic..........www.atomicspeakers.com (call them for a dealer) |
Silver Member Username: Mike_16Burlington, Wisconsin Us Post Number: 617 Registered: Aug-06 | that sub is single 3 ohm so how woul du run that ? |
Gold Member Username: Trey4sportsPost Number: 1388 Registered: Sep-06 | dude get an RD SHW and call it a day. run 5K to a 15 inch SHW with 4 inch coils and build yourself a nice lil box |
Silver Member Username: 04redmach1Columbus, GA USA Post Number: 965 Registered: Mar-06 | Chad that looks clean bro. Tailpipes the size of your sub FTL ![]() J/K Kevin |
Platinum Member Username: BestmankindSEALED IS THE ONLY WAY Post Number: 13955 Registered: Oct-05 | lol yea. |
Bronze Member Username: Sick96vtecaccordVa Usa Post Number: 14 Registered: Jun-07 | I have a 1996 4 door Accord Ex with an MTX 9500 in it and that mofo bangs hard as sh*t.I think it depends on what you want to spend you have a lot of options to work with. |
Gold Member Username: Mygame5982I Got More Watts Then ..., TEXAS US Post Number: 2051 Registered: Jan-06 | get a orion 2500d and two type r... |
