running a 4kw and 3004(75w x 4). I'll have a 240A alt. My question is how many batts should I be looking at running? I'll have a Kinetik 1400 under the hood, so what else do I need in the back? I was thinking just a 2000 would be ok. Thanks for any input as I've never run multiple batts.
either way, with those two batteries or greater along with the alternator you shouldnt have too much voltage drop to make it a concern. depends how you listen though...
