Amp problem!!! Help!!!
Username: Bigdaddyyoung03
So here is the deal. I was driving down the road with subs going string. Then slowely it sounded liek they got weaker and weasker till nothing. Now my amps power light flashes every 10 or so seconds and my subs try to hit when it flashes. I check the fuse and akl power connections. They looked fine. I just checked grounding and it looked ok too. Any ideas?
Username: Kpa2727
Post Number: 260
amp sounds toasted i say still throw another fuse it in see what happens, even it it looks fine it could be messed up , after that if nothing the amps power supply sounds screwed.
