Bronze Member Username: Mrbockbagok
Edmonton,
Alberta
Post Number: 29 Registered: Feb-06
Posted on Is there a way to hook up either 2dvc 2ohm or 2dvc 4ohm, to get them to pull 1ohm from a amp? |
Gold Member Username: Loudon
Post Number: 1319 Registered: Jun-04
Posted on you can hook up 2 dual 4ohm subs to make a 1 ohm load ... but a dual 2 ohm woofer x 2 .. will make 2 ohm load ... |
Edmonton,
Alberta
Post Number: 30 Registered: Feb-06
Posted on Perfect thats what I needed thanks a lot. I remember seeing a diagram around before on how to do it, but couldn't remember what Ohms the subs where. |
