Silver Member Username: Big_edge_headMilwaukee, Wisconsin USA Post Number: 225 Registered: Mar-07 | my system is: -pioneer 3800 HU -diamond audio d352 5.25 components(no amp yet) -rockford fosegate p6002 for subs -2 12'' SD2.5s i want an eq to cut some freq.s cause sometimes theres just too much bass and its just overkill. i want an eq that i can adjust at my fingertips when i see fit to. so i was wondering if theres anyway to set up this eq, without an amp for the speakers.(will get one in the future) and when it is hooked up would i re-set the gain on my amp? http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=16889 i was thinking either that or somthing else within that price. |
Gold Member Username: Van_manBoston South, MA Post Number: 2615 Registered: Mar-06 | Check this one out. It has 5.1 and is a parametric EQ. I use it with no complaints http://www.overstock.com/Electronics/Performance-Teknique-ICBM5EQ-5.1-channel-Pr eamp/1496501/product.html |
Gold Member Username: JakeyplaysbassSt. Louis, MO Post Number: 1820 Registered: Jul-05 | that clarion acutally isnt half bad for the price. my friend has a clarion HU and the EQ and it sounds good, its also very easy to install. |
Silver Member Username: Big_edge_headMilwaukee, Wisconsin USA Post Number: 226 Registered: Mar-07 | sorry marc but i dont want a parametric EQ. but with out an amp for my speakers what will i be able to eq till i get and amp for my speakers. and would i use the sub level contronl on the eq for the sub and the HU for the speakers? |
Silver Member Username: Big_edge_headMilwaukee, Wisconsin USA Post Number: 227 Registered: Mar-07 | bump |
Silver Member Username: Big_edge_headMilwaukee, Wisconsin USA Post Number: 228 Registered: Mar-07 | bumpdamnit |
Silver Member Username: Big_edge_headMilwaukee, Wisconsin USA Post Number: 230 Registered: Mar-07 | bump |
Gold Member Username: DrivingrecklessDD 9515f, 147.8 db Mov... Post Number: 3665 Registered: Apr-06 | GTFO NOOOOOOOB |
Silver Member Username: Big_edge_headMilwaukee, Wisconsin USA Post Number: 231 Registered: Mar-07 | shut up dave. i just want some other peoples input |
