New member Username: DannBritish Colu... Canada Post Number: 2 Registered: Jun-07 | whats the best way to hook up my dual 2ohm subs to my amp. Amp is a clarion dpx 1800 1ohm min.I have it all hooked up at 1ohm right now. |
Silver Member Username: Kpa2727Post Number: 144 Registered: May-07 | that's prob the most effecient way. theres not much more u can do other then a lower ohm rating. |
Silver Member Username: Kpa2727Post Number: 146 Registered: May-07 | i mean higher ohm, sorry i'm tired as hell. |
New member Username: DannBritish Colu... Canada Post Number: 3 Registered: Jun-07 | or better subs? |
Bronze Member Username: Chuck78Post Number: 45 Registered: Mar-07 | i don't think you can hook up 2 2ohm subs at 1ohm.... all i can think of is 8, 2, and .5ohms. How do you have them wired? series/parallel? type r's are good subs, i just don't think you have them wired right.. and what are the specs of your amp? (rms not max plx and ty) |
Gold Member Username: StnorrisRE SX 15, IA US Post Number: 2172 Registered: Apr-06 | 2 dual 2 ohms will wire to .5ohms, 2 ohms, and 8 ohms. You must have them currently wired in series @ 2 ohms and ur pushin around 900rms probably. Thats the best way to wire them to this amp. |
Silver Member Username: Kpa2727Post Number: 154 Registered: May-07 | ah yea i just got up i was pretty tired last night i was thinkin dual 4 0hm instead of 2 ohm so yes they cannot be wired to 1 ohm to the best of my knowledge. |
Silver Member Username: JkidderSpring hill, Florida Usa Post Number: 888 Registered: Nov-05 | it has nothin to do w/ the best or worst of ur knowledge. it has to do with electrical engineering and physics. its not possible! |
New member Username: DannBritish Colu... Canada Post Number: 4 Registered: Jun-07 | the specs on my amp 800 Watts of Maximum Music Power 450W × 1 Into 4 Ohms, 20Hz-20kHz @ < 0.05%THD 800W × 1 Into 1 or 2 Ohms, 20Hz-20kHz @ < 0.1%THD Adjustable Subsonic Filter, 10-80Hz Remote Control Included Input Voltage Selector Precise Frequency Selector Variable Bass Boost; 0-15dB @ 30-125Hz Adjustable -12db/Oct. Low Pass Crossover, 50-250Hz Gold Plated Connectors; RCA/Speaker/Power Speaker Level Input Dimensions 19 1/4" × 12" × 2 7/8" |
New member Username: DannBritish Colu... Canada Post Number: 5 Registered: Jun-07 | CEA 2006 Power Ratings 800W x 1RMS [2U@14.4V A1% THD+N] 450W x 1RMS [4U@14.4V A1% THD+N] S/N 79dB (Ref:1W into 4U) So after all that what would be the best way to run at. |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 4729 Registered: Dec-05 | www.the12volt.com hit the link woofer wiring |
Silver Member Username: Kpa2727Post Number: 185 Registered: May-07 | btw jk it does to, if u got 1, 2 ohm dvc they can run to 1 ohm if it's dual 4 ohm then no. i said i was tired don't be obnoxious. |
