"Hi, I've recently learned some Fortec STAR Lifetime Ultra coding. I'm releasing my first bin. It's safe for all Pansat 2500 Clones with some autoroll improvement. This bin has been tested by 17 people and so far, we're getting positive results. I'll be working for DSS Rookie, and therefore this bin belongs to this website (you can even see this website's name when you got to System Information). Enjoy! And, please reply because this is my first post on this website."
YO! DO NOT DOWNLOAD THAT BIN BECAUSE IT GAVE ME KNIGHT RIDER LIGHTS NOW! I M SWITCHING BACK TO BIN 289T. THAT FORTEC MAN WHO'S MAKING THESE BINS ARE NOT GOOD. USE CHANCYSAND BINS ONLY!
Yes, this bin is not safe. This new coder is making bins, which aren't good. So, switch back to Bin 293T and from now on, only trust bins that're by Chancysand.
I see the bin was removed from dssrookie after Chancysand drew some attention to it, and others experienced knight riders.
A lesson here, I guess, as mentioned above, stick with Chancy's bins for now. Even more, make sure they are in fact from Chancysand, as we saw with this one it was named in the same way (with a "T" after the version number); could have caused a lot of havoc and confusion if it made the rounds.
AV, your initial comment "working fine for me", if not "eratic" was certainly not helpful. If you had even actually managed to load the file, it would not have worked at all.
Therapo's post had the " mark at the appropriate place to indicate a C&P. AV: Do I need to go back to the early days of Summer of 2006 to explain? I would rather note. Just take care next time and as Therepo suggested, test it first fully before advising.
People ... It worked then got Knight Rider lights .... its not my fault that it worked for 2 hours and automatic turned OFF and got knight rider lights
