New member Username: Haven_52Post Number: 2 Registered: Jun-07 | hey i'm new to the car audio world and just wanted some help with my system. I bought a kicker enclosed system (2 cvr 10's in a vented box) and i also have a 2000 watt 2 channel amp. will the amp work well with these subs? how do i know how many ohms my subs are..it says 2,4? |
New member Username: Nate_d_001Augusta, Georgia Post Number: 3 Registered: Jun-07 | What kind of amp do you have and what ohm does the speaker box (Cardboard box) say and if you dont have the box well you need to ask who you bought them from or take speaker out sub box. your looking fo DVC SVC and ohms. Just from the description and the amp watts it should work fine. |
New member Username: Haven_52Post Number: 3 Registered: Jun-07 | well it's a 4 ohm set of subs...so how do i run these subs off the 2 channel amp? do I bridge the channels or just run the box off one channel? |
New member Username: Haven_52Post Number: 4 Registered: Jun-07 | oh and i have an off-brand amp that runs 250w @ 4 ohm and 450w @2 ohm |
New member Username: Nate_d_001Augusta, Georgia Post Number: 4 Registered: Jun-07 | use this it will help you on how to wire your speakes. http://www.crutchfield.com/learningcenter/car/subwoofers_wiring.html I still dont know if svc or dvc (if it has 2 +POS & 2 -NEG on each speaker its DVC if it has one of each its SVC. Or how many watts can you speakes handle. |
