4 ohm sub....4 ohm 2 ch. amp(2 ohm bridged)...can i make it work?
Evry1 Help Steve!
my sub is an infinity 1220w: 4 ohm
my amp is a kicker IX 252: 4 ohm and 2 ohm mono
i tihnk i mayu have blown my sub by hooking it up b/c it does not work unless I push on the center...it was the first time i tried it and i got it from eBay so i dont know if i broke it or if it was already broke but it looked BRAND NEW...
anyways...i need to make this work! is it possible?
how do you have it wired?
is your subwoofer dvc or svc?
if it is single voice coil, this is how you wire it:
http://www.rockfordfosgate.com/rftech/wiringwizard/index.asp?WoofQty=1+woofer&WoofImp=Single+Voice+Coil+-+4+ohms&image.x=16&image.y=10
if it is dual voice coil, here is how u wire it:
http://www.rockfordfosgate.com/rftech/wiringwizard/index.asp?WoofQty=1+woofer&WoofImp=Dual+Voice+Coil+-+4+ohms+x+2&image.x=18&image.y=15
