Bronze Member Username: AjockeyPost Number: 14 Registered: Apr-07 | im trying to upload a fix for a megasat yt6688 but every time that i open loader and try to flash unit using com2 i get a a message "cant open serial port "the system cannot find file specified" now im using a laptop toshiba satellite with a usb to serial adapter, i installed the disk it came with, but if a change the com to com3, i do get "a processing " but nothing is going to the stb, i do follow required proccess turn unit off, hit pc>stb then turn unit on but nothing happens , no process bar , (0%) does anybody know how to change my settings to com2 on computer or any ideas , i will thank you guys.... |
Gold Member Username: NydasPost Number: 2903 Registered: Jun-06 | On a PC, you should go into the Device Manager. START/Settings/Control Panel/Admin tools/ Computer Managment/Device Manager The Megasat uses straight cable not a null modem cable. I think it is a clone and use a clone safe BIN and make sure you have unzipped the file. |
Platinum Member Username: LklivesPost Number: 10124 Registered: Jan-06 | PINHEAD....NEVER PUT ME IN THE SAME CATEGORY AS THAT IDIOT NALIN...SHE IS NO EXPERT...AND IN FACT IS A NEWBIE WHO DOESN'T TEST AND IS NOT TAKEN SERIOUSLY HERE BT THE KNOWLEGEABLE FTA USERS! |
Gold Member Username: NikkPost Number: 1881 Registered: Sep-06 | Take a look at the notes that should be on the same disk as the driver for that adapter, the software will assign a predefined com port to it, check what port number is assigned by the software and select the same in the loader... If you get the "processing" message that means that you are selecting the right com port but it is better to get sure about it reading the notes, also check the cable that you are using, you need a RS232 Straight through cable, it should have this configuration: |
Silver Member Username: EdenmanPost Number: 421 Registered: Aug-06 | LOL Great thread title pinhead ROFLMAO |
Platinum Member Username: LklivesPost Number: 10137 Registered: Jan-06 | pinead gave it this title to bust my balls...LOL...I am NO Expert...and nalin is NO tester...U cannot group us together...we are as different as apples and oranges.. |
Silver Member Username: BanejPost Number: 217 Registered: Jun-06 | you might be different but at the end you are all just a fruit. |
Platinum Member Username: LklivesPost Number: 10139 Registered: Jan-06 | hey now...watch it...I resemble that remark...LOL I think I am a banana due to my lower anatomy....LMAO |
New member Username: Sobe1South beach, Fl Post Number: 10 Registered: Jun-07 | and i am a zuccini |
Platinum Member Username: LklivesPost Number: 10142 Registered: Jan-06 | aah...that just means its been "squashed" ....lol |
Silver Member Username: AmexPost Number: 126 Registered: Nov-06 | "and i am a zuccini" man.........cant believe the extent of some people's gayness . |
New member Username: Lks_right_hand_manPost Number: 4 Registered: Jun-07 | Take a look at the notes that should be on the same disk as the driver for that adapter, the software will assign a predefined com port to it, check what port number is assigned by the software and select the same in the loader... If you get the "processing" message that means that you are selecting the right com port but it is better to get sure about it reading the notes, also check the cable that you are using, you need a RS232 Straight through cable, it should have this configuration: Quite often the pin falling out of the johnson bar can mimick the same symptoms. It`s not that likely but always check to make sure yur pin is firmly through the johnson bar before taking above steps. |
Platinum Member Username: LklivesPost Number: 10165 Registered: Jan-06 | Well well...Now i know who "LK's Right hand man" really is...its Dirty Democrat!, the anti abortion and Republican obsessed preaching fruitcake... The "johnson bar" thing gave u away!...LMAO...why the need to change your nick and username?..a new alias!...are U ashamed?...or was your "Dirty Democrat" preachings all a farce to generate more posts for Ecoustics (something an admin may do here) https://www.ecoustics.com/electronics/forum/home-video/360065.html |
