What size\actual specs can i use for a box for 3 type R's?
Username: _jay_
Post Number: 214
what kind of box can i build for 3 type R's....that make em loud in my 96 2d grand am..i have 18tall by 35deep about...inches...no tape measure...
Username: _jay_
Post Number: 219
anyone?!
Username: Cried
Erie, PA US
Post Number: 414
10's 12's or 15's?
Username: _jay_
Post Number: 220
12s
Username: Cenus
Hicksville, Ohio
Post Number: 3289
i'd go around 8cf tuned to 35hz, that should get pretty "loud".
Username: _jay_
Post Number: 222
wwell i got 32"L X 37"W X 17"Tall hopin for around 32-35hz..
Username: Cenus
Hicksville, Ohio
Post Number: 3290
using those measurements it would be around 8-8.5cf, so using 2 8inch ports, 21inchs long would give you a 35hz tune with 100sq inches of port. http://www.bcae1.com/spboxnew2.htm heres a link for help with boxes.
Username: Cried
Erie, PA US
Post Number: 420
Jay, do you need 1 type R? 12" dual 4ohm?
Username: _jay_
Post Number: 223
[QUOTE=Charlie Ried] Jay, do you need 1 type R? 12" dual 4ohm? [/quote]
no i don't charlie but thanks for the offer, i just got a good deal on three of them.
also dustin thank you, i'll kind of do a drawing and post it up here later...once i have time later..
Username: _jay_
Post Number: 224
http://img457.imageshack.us/img457/5163/untitledng8.png
lyke that?
Username: Cenus
Hicksville, Ohio
Post Number: 3301
yep just like that, if you need ports talk to cannan he makes flared ports and sells them, or just buy some 8inch pvc pipe.
Username: _jay_
Post Number: 225
couldn't i just make it out of the box and brace it? or would it be easier to buy PVC? i think pvc would be easier lmao..ty alot dustin :]
Username: Rovin
4 10 Pioneer...
Post Number: 11694
just make sure each sub gets @ least a 2cuft after displacements - tuned 34hz would slam ......
Username: _jay_
Post Number: 227
so rovin, would what dustin directed me to do would be the ideal thing to do?? and what i posted i' would be doing.
Username: Rovin
4 10 Pioneer...
Post Number: 11697
er im too lazy to go calculate what he said but my post was a quick guide ,i used that when i had my Rs ......
Username: Cenus
Hicksville, Ohio
Post Number: 3313
using these measurements " 32"L X 37"W X 17"Tall" i get 8.19cf net after port and speaker displacement, and using 2 8icnh ports 21.002inchs long would give you a 35hz tune with 100.553sq inches of port area. so that would be 2.7cf per sub, i think that would be perfect. and if you think my calculaions are wrong check this site http://www.bcae1.com/spboxnew2.htm go down to where it says ported enclosure and enter all the measurements.
Username: _jay_
Post Number: 228
wow, well thank you very much dustin, sorry for not achknoledging you 100 percent (sorry early..can't spell haha)
Username: _jay_
Post Number: 231
well i just checked dustin\remembered that i won't have enough room to put 3 subs and 2 ports on one side so what if i had the subs on one side and then the ports directly behind them??
lyke this>>> w\ subs fire'n into my car?? or would it be louder w\ ports firing into my car???
http://img522.imageshack.us/my.php?image=untitled1nx2.png
Username: _jay_
Post Number: 233
Username: Cenus
Hicksville, Ohio
Post Number: 3318
ya that would work, but i'd recomemned having the subs firing up and the ports firing back, but either would work.
Username: _jay_
Post Number: 235
http://img526.imageshack.us/my.php?image=trunkspecsqz8.jpg
thats what i got
um friend told me to make it 38wide by 34 long by 14.5tall but how much\big of a port should i have to make 32-35hz?
Username: Cenus
Hicksville, Ohio
Post Number: 3320
sorry man but im tired of desingning boxes just go to the site i said eneter the dimensions and roll with it.
Username: _jay_
Post Number: 236
hahaha! its ight i'll try i guess.
Username: _jay_
Post Number: 238
how much is speaker displacement?? and sq port ratio?
Username: _jay_
Post Number: 240
fawk i tried..messed it all up.i can't get it lmao
Username: _jay_
Post Number: 241
i could still use help...please anyone?
