Finally got my BTLs In
Username: Northomaha
Post Number: 444
Put my 2 15" BTLs and my Visonik 4000d into my Caddi. It beats extremely hard. I have found the point where i no longer want to get louder. This is awesome. Fi makes some GREAT products. I need to get it metered. The voltage seems pretty stable. It gets down to about 13.2 on songs that hit hard. I figure thats ok as long as im not goin beneath 12.5. I think the optima in the back is helpin out. Ill get pictures up tommorow.
Username: 420alldaylong
Post Number: 2070
Beatin down the block thats what it's all about.
Username: Basssquared
Kansas
Post Number: 673
Hey C.Reming your the perfect person to ask since you own one what do you think of Visoniks amps build quality and wattage output
Username: Andrew571
Post Number: 915
nice, pics...vids?
Kansas
Post Number: 683
So what do you think man?
Post Number: 445
i personally think its a awesome budget amp. with a good charging system you could get 3750 outta the amp. i also think that the ma hk4000d is a great amp (same board as visonik) its got a great cooling fan that keeps it from getting hot, even in the trunk. i dont want to jinx it tho, i only have had it hooked up for three days now. it pounds tho.
Username: Cenus
Hicksville, Ohio
Post Number: 3305
how many and what size of fuses does that amp have?
Post Number: 2079
C. Reming
How big of gauge does the amp take?
How big of alternator do you have?
Post Number: 446
the amp isnt internally fused, the inline fuse from my battery in the trunk is the only one. the amp takes 0awg cable. my alt is my stock 145amp alt. i hope to upgrade that soon but i did the big three and i do not have voltage drops below 13.0volts.
Post Number: 447
i really think that visonik/ma hk4000d are getting a bad wrap. i havnt heard any bad reviews of the amps. i know there not orion or zapco but for the money you cannot beat it. i also got a real good deal on mine used.
Kansas
Post Number: 692
okay thats it thanks C. Reming im getting one well not a 4000 watt one but one that gives 1500 at 1 ohm for 200 dollars thats a steal thanks for the advice main
Username: Th3pwn3r
Post Number:...
Post Number: 3229
"i know there not orion or zapco but for the money you cannot beat it. i also got a real good deal on mine used."
You should never put Orion in the same sentence as Zapco.Orion is complete trash in comparison to Zapco.That's Like comparing Funky Pups to a Fi Q(The Funky Pup being better of course :-) )
Post Number: 448
you obviously know nothing about car audio because funky pups are top of the line. haha
SQ IS THE ONLY WAY
Post Number: 13736
c reming i could only imagine how loud your 2 btl's would be on 4000wrms. you are one loud azz. very nice. congrats on having a pair of fine subs in your ride.
Username: Joebruce
15 Inch Wang...
Post Number: 1042
Rob Orion used to be as good as Zapco back in the day. Ive owned a Zapco 2.0 and own a orion 225g4 and i had the zapco on some coaxials and the orion on my sub and i switched them and i could not tell a differance at all in the coaxials but the sub sounded much cleaner and louder with the g4. If i could afford it, I would run all Orion g4s or the other older orions,great amps!
Username: Adam_s
Post Number: 1377
Username: Th3pwn3r
Post Number:...
Post Number: 3242
I was talking about now-day products not from a decade ago.
"If i could afford it, I would run all Orion g4s or the other older orions,great amps!"
It would be nice if you could actually find them.Zapco is top tier,Orion has fallen off long ago my friend :-( Oooh Mcintosh amps are no joke either but they're not as popular as Zapco.Mcintosh are also very expensive.
A pic is worth 1000 posts!!
Post Number: 7713
Username: Hgihkcin
Lincoln, NE
Post Number: 199
c reming if u got it in three days ago why didnt you get it metered at stereo west on two days ago
Post Number: 450
i went fishin instead haha.
Username: Adam_s
Post Number: 1400
I want pics NOW!!
Username: Hgihkcin
Lincoln, NE
Post Number: 200
yeah get some pics, you shoulda went.. i was the only person there with an fi
