Is there a way....
Username: Salmiery
Martinsburg, WV
Post Number: 21
I have a Pioneer DEH-P3700MP... stock ford explorer speakers - I want the bass out of my speakers completely and all going straight to my subs... How can i do this??
Username: Salmiery
Martinsburg, WV
Post Number: 23
Username: Adddisorder
West palm, Florida
Post Number: 4512
high pass your speakers
Username: Salmiery
Martinsburg, WV
Post Number: 24
Without buying new equipment......
West palm, Florida
Post Number: 4517
that deck should have built in high pass crossover.
Username: Kpa2727
Post Number: 87
i've done this with no problem if u bougfht a decent pioneer super tuner series you should have no problem. you turn on high pass ad tweak your frequencys till u have it like you want or even try a loud setting.
Username: Salmiery
Martinsburg, WV
Post Number: 32
well - I turned it to the hi +6, mid +2, and the low -6.. but it still gets distorted when i turn it up past 45
Username: Salmiery
Martinsburg, WV
Post Number: 33
any ideas?
West palm, Florida
Post Number: 4586
look in your manual and see if it says anything about having a crossover. also are they on an amp?
Username: Salmiery
Martinsburg, WV
Post Number: 34
I think the explorer has a built in amp somewhere which they are run off of. But no they are factory speakers.. I found the supertuner features, thats all ive found for the crossover
Username: Kpa2727
Post Number: 102
turn off mids and sla up and turn on the hpf setting aka high pass try 80 hz if no go flip through them but turning on mids demands more sound or bass depending on the song so thats distorting u .
