Custom systems
Username: Justinp21
Wyoming United States
Post Number: 12
Hey Just a quick question, has anybody ever hooked up a system for a fiero?? there is not a whole lot of room in there so i was wondering if anybody else had any luck finding a way. any suggestions would be appreciated!! (if anybody has pictures of their own i'd love to see them) THANKS!!
A pic is worth 1000 posts!!
Post Number: 7752
Maybe a good pair of headphones? Those cars are tight.
Username: Cenus
Hicksville, Ohio
Post Number: 3315
LMAO a fiero, i know a guy who had an 8inch kicker comp in one, that was untill he hit another car going 20mph and totaled it, lmao.
Username: Gavbo211
JL Audio 10w3v2, IL US
Post Number: 527
is there any room behind the seats? if you can't fit a "real" sub back there.. maybe something like those shallow mount subs (pioneer makes some, i know) might work? other than that the only place would be in that front compartment, if there is even room in there, and it would prolly sound like po*op if you could even hear it at all.
Username: Justinp21
Post Number: 13
ha! well yeah ive considered most of those options, im thinking that behind the seats may be my only option, have u guys seen how the seats have speakers built in?>> i might as well wear headphones... well thanks guys
Post Number: 7757
Might want to look into bass shakers.
Username: Jmp21
United States
Post Number: 15
Thanks, never considered that... do you think one under each seat would be enough?
Post Number: 7768
Only if you have a passenger.
http://www.smarthome.com/8249p.html
