Help with lifetime ultra
Username: Lionking
Post Number: 32
My lifetime ultra is stuck at menu and every time i try to exit it gets stuck at the language and will not go back. I tried loading the bin again but it gives me error message
Username: Techme
MIAMI, FL USA
Post Number: 39
TURN OFF AUTO ROLL
Username: Lklives
Post Number: 10049
Do a factory default and factory bin...clear out the memory corruption..
next time u post...explain what the error message ACTUALLY says, the details are important..like "flash failed" etc is usually using wrong cable or comport..
Username: Techme
MIAMI, FL USA
Post Number: 45
lk for some reason on lifetim ultra ive tried factory bin default and load 293t and still same problem ive only had luck with quantum 3000 clone of 2500 lk do you think there are old bins that still autoroll.
