Guess what my q install got metered at on termlab
Username: Hgihkcin
Lincoln, NE
Post Number: 191
18" fi Q
jbl 1200.1
mitsibish eclipse
4 gage wire
stock headunit
5 cubic feet sealed box
Username: Jblanford
Post Number: 1532
Username: Adam_s
Post Number: 1376
141.3
Username: Goodie_goop
Midland, Texas U.S.
Post Number: 641
Username: Ctmike
Ct.
Post Number: 4731
Username: The_image_dynamic
San Diego
Post Number: 1942
Username: Wolf_hound
Post Number: 298
139.2
Username: Oglejust
Post Number: 2070
Username: Big_edge_head
Milwaukee, Wisconsin USA
Post Number: 192
just f'in tell us
San Diego
Post Number: 1945
Shut the fuck up Big Edge Head.... we could win $500.
Username: Hgihkcin
Lincoln, NE
Post Number: 192
got a 141.7, but i didnt know the resonant frequency so i just did some test tones they gave me, so i pry would have gotten alot better if i knew it at the time, also the amp keeps cutting out, either from heat or from voltage drop, so im gunna do another run of 4 gage, do the big three with 0 gage, fiberfill the box, put fans on the amp, and put some bracing on the box cuss it flexes some, i wana get upto the 145+ area. anybody got guesses where im gunna be after i do all that? and any more suggestions(besides porting it, i dont wana do all the work), i think its pretty good for my first install with any sub that could do anything (i installed alota really cheap subs for my friends)
Username: Jblanford
Post Number: 1534
good luck on 145 with that sealed box
Username: Hgihkcin
Lincoln, NE
Post Number: 193
yeah i know its almost impossible but its something i wana get... there was a van that got metered like 10 minutes before me that got a 157.6 which was pretty sweet, but he probably spend like 10 times what i did, with a budget of 500 bucks. there was a crx that hit 158 with a single 12" juggernaut on two dd z1's
Username: Th3pwn3r
Post Number:...
Post Number: 3230
" anybody got guesses where im gunna be after i do all that? "
You're gonna be shopping for a new amp and sub when you blow it up from all the voltage drop that you were talking about.
SQ IS THE ONLY WAY
Post Number: 13735
nice numbers nick. that is loud.
Username: Northomaha
Post Number: 449
where did you get it metered nick? stereo west?
Username: Hgihkcin
Lincoln, NE
Post Number: 195
yeah, do you live in omaha? what kinda system do you have, it woulda been nice to see another ecoustics person there
Username: Skibum12189
Cleveland
Post Number: 771
how does that sound in 5 cube sealed box, damn thats huge
Post Number: 196
what $500
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 4296
158 with a a single 12? are we metering in the kick?
Username: Hgihkcin
Lincoln, NE
Post Number: 197
in the 5 cube box it sound pretty good, thats the smallest scott said to make it for an 18", yeah just about 500 dollars, sub 300, amp 200, and then the rest of the crap except the periphrial i had laying around. and nope that 12" was on the dash.
Username: Insearchofbass
Post Number: 5370
trevor you gotta remember that is a crx.....they dont call it "Rex" for nothing from what I read they hit like 59 hz pretty good and the angle on the hatch helps alot
Post Number: 5371
also I think subs up ports back is key in the crx last I read
Post Number: 5372
let us know what the poly does my guess is if it goes up it will be at a lower frequency than before after the poly
Post Number: 5373
and if thats the case then id port it and you might get your 145 db......but fix that voltage drop for sure or you will kill your equipment
Post Number: 4299
no matter what car 158 isnt easy to achieve though. and yes, CRX box is subs up, round ports firing back along the bottom of the enclosure. for a higher number sealed i would lessen the volume. but it seems you dont want to build a new enclosure....however you could put something in it to subtract volume. try maybe taking out 1cuft and the poly.... then 1.5cuft ....then 2..
Post Number: 5381
yeah two l7 10's hits 155 around here in a crx I forget the power though
Post Number: 5382
wish we could mess with my buddies crx but my bro says the factory alternators on them are crap
