Expedition radio wiring help PLEASE!!!
Username: Intimidatr
i am trying to wire a yu3f-18c868-aa i think from a 2002 expodition, into my 1998 expodition xlt witch has a f75f-19b165-da stereo in it now, the speaker wires seemed to match by color, but the acc and batery ac for power donnot match, if anyone could find out for me at least the power wire colors for the two radios that would be helpful or if anyone could find the full wire color code for both those radios i would be immensly thankful.....}
Username: Imalik
SD2.5......ED9.1=Boom, New Jersey Audioque...N...
Post Number: 372
Just buy a new wire harness for the 1998
well you see that only solves half the problem,,, i dont know the colors of the wire on the new stereo and being an OEM the wire colors dont match the aftermarket colors on the female adapter, also, no conversion adapter is avalible that i can find
By the way, the expedition has "premium sound" witch as i understand makes a difference pertaining to wires
Username: Skies
Courtenay, British Colu... Canada
Post Number: 771
http://www.the12volt.com/installbay/stereodetail/852.html
