My new HT sub box *PICS*
Username: Snarl2004
Audioque 12 SD2.5s, Earthquake P...
Post Number: 1389
for 1 10" sub
1.6 net ft^3
28hz
the cutout for my plate amp
box with the sub and amp cut outs
gunna become the ports
the cut ports
the ports installed
the finish product
some pics of where i work
just a green house with xmas lights and a working light. it works lol
another view of my shop
sry for the bad pics but its from a phone
Username: Logan__tille
Team RevolutionImortal Box ...
Post Number: 8134
Phone pics are better than no pics:-)
Nice job.
Username: Snarl2004
Post Number: 1391
lol ya i was to lazy to go inside and get my digital camera so i just used my phone. it works preety good in the daylight but not so well at night
Username: Skibum12189
Cleveland
Post Number: 746
working with saws at night in the dark except for xmas lights FTL
ahha jp dude, it works, looks like youve got all the room you could ever need
Username: Joebruce
15 Inch Wang...
Post Number: 1041
What sub you gonna be using?
Username: Volfenhagking1600
SSD Wangin, Shawano, Wis... USA
Post Number: 818
how do u transfer pics from yuor phone to the cpu?????
Username: Gavbo211
JL Audio 10w3v2, IL US
Post Number: 518
that shop is awesome. i love greenhouse type buildings. awesome box too. how long till you get to test it out?
A pic is worth 1000 posts!!
Post Number: 7631
Good progress dude. Whatcha powering your sub with? What sub? Covering the box?
Username: Th3pwn3r
Post Number:...
Post Number: 3213
That box is going to both leak and shake the sh1t out of your plate amp Unless I'm looking at the picture wrong and you should dye or paint those ports black and carpet that bad boy.
Username: Mike_16
Burlington, Wisconsin Us
Post Number: 614
i had a friend make me a box last summer an dit had no ports lol so i just did wut he did cut that same type of tubing and used it but it sucked it leaked and sounded crapy, i didn tknow anyhting realy abou tporting yet soo
Username: Snarl2004
Post Number: 1397
I plan on painting the box black but it will be in the corner of the room behind a lot of junk so ur not gunna be able to see it anyway.
Its gunna be a 10" RD sonance powered by this:
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=300-752
Jamie I have a Razr and it has a usb port on the side so i can plug it into my copputer and retrieve whatever is on my micro SD card.
I will test it as soon as i got the sub and amp. I will probly order them both next week so as soon as they arrive ill get to test it out.
Username: Snarl2004
Post Number: 1398
o and rob it will shake the plate amp but plate amps are ment to be installed in boxes so it will be fine. Its not gunna leak around the amp cuz theres rubber inbetween for a tight seal. As for the rest im putting sealent around the whole thing so it wont leak at all.
Post Number: 7653
I had that very same amp. Bash makes a good plate amp. I sold it to someone here when I upgraded to the Dayton 1000w.
