hi!! I have a very stupid question but whatever... I just brought 110 and 119 and 110 doesn't seem to work. It keeps on saying channel scramble on 110. The signal is around 90 percent. What does that mean?!? 119 works perfectly fine. Please help
Sandy - I'm not sure what you are trying to say by "I just brought 110 and 119". Have you aligned the dish properly? Is the Antena configured properly in your receiver? I would suggest you do a little reading at any of the sites listed in the Reputable Sites posted here to understand a little better and then ask the question if you still have problems.
Actually, I have 119 a couple of days ago and it works perfectly fine. So, I decided to buy 110 so I can watch both 110 and 119. But once I brought it, 110 has a signal but it on saying channel scramble on every channels but 119 still works. This is very confusing?!?
Sandy - You really need to read. If you are paying someone to do this when you can do this yourself, the best thing you can do is follow my advice and learn a little about FTA before going any further.
