Bronze Member Username: Hokiefan4life100Post Number: 20 Registered: May-07 | alright im running 2 12" SE's on a RE 12.1 and CDT HD-62's on a jl 300/2 and i killed my battery. I took my system out and im about to go buy a new battery. The guy told me that instead of getting a HO alt i could just get a 2nd battery, yellow or red top, and be alright. He said it would probably be about 150$ cheaper. Input on if this is true? Also, im proabably about to sell 1 of the SE's to someone on here if someone wants it, would 1 12" SE and the CDT's run on my stock alt and battery or what should i do then? |
New member Username: Spliff_burtonOklahoma City, Oklahoma USA Post Number: 3 Registered: Jun-07 | My shop told me to get one of these batteries and it should be alright with the regular battery I have... $118 is kind of expensive to me though, they were gonna charge me $175 plus tax. haha. Kinetik HC800 750 CA Power Cell Battery [url]http://www.techronics.com/index.cfm?fuseaction=product.display&Product_ID=3955[url] |
Silver Member Username: Skibum12189Cleveland Post Number: 735 Registered: Mar-06 | could've just been a fluke man, old battery? the RE amp and the JL are both great amps, very very efficient and you should be able to run all of that on a stock alt unless its like 80 amps... generally, adding a second battery won't really help bc your alt might not be strong enough to keep it charged.. try buying some 0/1 gauge and doing the big 3 upgrade and see if you're still having problems... but mainly, i feel as if this was just a fluke, you should be fine on your stock alternator important point: if and when you sell your RE 12.1, you need to contact me.. |
Bronze Member Username: Hokiefan4life100Post Number: 21 Registered: May-07 | alright well i took my subs and 12.1 out of my car and i left my components in. Just got a new battery, titanium something from autozone. i just tested it out without the subs and its running fine right now, and ill find out further when i go to see oceans 13 with my girl. Ill post pictures of the SE's and 12.1 in the next day or two once i find a digital camera. |
