Which Sub-Woofer cable to buy?
Dave
Which subwoofer cable do you recommend (don't need top of the line - but would pay for a good Monster item if worth it). To be used on Onkyo 760 System. Thanks.
timn8ter
Monster is overrated and overpriced. If you're not going to make your own, which is amazingly inexpensive and if done right the best way to go, then go to http://www.bluejeanscable.com/store/single/subwoofer.htm
