Silver Member Username: LegacyaudioPost Number: 196 Registered: Feb-05 | now that tcab is bon ing people hardcore, im looking for a person or company, well respected, who will be able to make me a decent box, not very big, for one 12 in eclipse ti. the only reason i cant make it myself is that i need it angled and the sub needs to be in a certain spot so it can fire through an opening in my backseat. any suggestions/help |
Gold Member Username: CtmikeCt. Post Number: 4690 Registered: Feb-06 | www.fishercustoms.com www.woodlawncabinetry.com logan and canaan on here makes them as well. just don't trust everyone here for your box |
Gold Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 7347 Registered: Jun-06 | I have the very same sub. Will be selling soon though. |
Gold Member Username: Logan__tilleTeam RevolutionImortal Box ... Post Number: 8049 Registered: Feb-06 | Where did you get that Paul? |
Gold Member Username: Freezeman_7C.FREE Post Number: 1367 Registered: May-06 | Imortal Box Building FTW! |
Silver Member Username: CriedErie, PA US Post Number: 277 Registered: Jun-07 | I have experience in box building and would be glad to assist you if you are interested. |
Gold Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 7354 Registered: Jun-06 | Logan. From Isaac W. That's the sub I replaced the surround on. |
Silver Member Username: TatonkaPost Number: 426 Registered: Mar-07 | I'm ready for charlie to finnaly build someone a box just because I'm curious to see how well it turns out. |
Silver Member Username: CriedErie, PA US Post Number: 280 Registered: Jun-07 | 80 shipped and its yours, you can see for yourself and write a review. |
Silver Member Username: TatonkaPost Number: 428 Registered: Mar-07 | Charlie are you saying that box is for a 12" sub? |
Silver Member Username: CriedErie, PA US Post Number: 282 Registered: Jun-07 | am I saying that, no, and its a 10" enclosure 1.25 cubes @ 32Hz |
Silver Member Username: camPost Number: 548 Registered: Nov-06 | a sub with different t/s parameters. get one made for your sub. |
Gold Member Username: HdubbFarmington, Nm Usa Post Number: 2082 Registered: Nov-04 | well i would think taking to your closet real audio shop would be the best bet. yes they will charge a lot to build it, but shipping a box made out of 3/4 mdf would be pretty pricy. and this way you will have a face to face, they will be able to see the way you want it formatted in you car, and usually they will back up their product. if you know someone that is nearby that gives you all of the same options go with them, but it is hard to find someone with all the tools to build custom boxes. anyone can build a rect. or square box, its harder to build a box that have mitered joints or dado joints. my two cents |
Silver Member Username: CriedErie, PA US Post Number: 286 Registered: Jun-07 | It all comes down to how much you wanna pay. Im sure if you're lucky enough to have a car audio shop in town that will build you a custom box to your specifications, they won't be cheap.. Probably in the upwards of 2-300 bucks. Sure it might be the upmost quality, but then again how much are you willing to spend, when someone on here can do it for half the price and do more than a sufficient job on it. IMO. |
Gold Member Username: OglejustPost Number: 1900 Registered: Aug-06 | ive been building boxes... do u have aim or msn? |
Gold Member Username: HdubbFarmington, Nm Usa Post Number: 2084 Registered: Nov-04 | but the only concern i would have is what if something goes wrong, the box rattles, it was not tested, it gets damaged in freight, gets wet, hole was cut to the wrong size, i guess just little things that woud make it a bad exp. and it is kinda hard to explain a custom box over the phone or through email. i think its one of those things you have to see in person or have seen and have a real good grasp on the concept and planning. |
Silver Member Username: CriedErie, PA US Post Number: 288 Registered: Jun-07 | This is the reason I downloaded Inventor 10 Software so I can design the boxes, give them the specs and let them see it before I build it. |
Gold Member Username: CtmikeCt. Post Number: 4696 Registered: Feb-06 | "but the only concern i would have is what if something goes wrong, the box rattles, it was not tested, it gets damaged in freight, gets wet, hole was cut to the wrong size" ^^and that's why i will only buy a box online from a very well known/respected box builder that has been doing it for some time now, has experience with packaging/shipping, etc. that or local is the only way for me. |
Gold Member Username: HdubbFarmington, Nm Usa Post Number: 2085 Registered: Nov-04 | yeah i just went through some other posts and saw some pics to this sort, looks impressive. i wasnt attacking you or anyone who builds boxes on here, dont want it to seem that way i just feel that seeing the car, the space where it is going and how they want the design is everything, and if you have the resources and skill to meet those needs at a better price then i would definitely go with that person. =) just i know that a lot of people dont have all the tools or perspective to do custom mitered boxes you know? but from the looks of it, your boxes look well planned out. |
