New member Username: Ballin_boi_03Post Number: 1 Registered: Jun-07 | I am trying to find some 12" inch subs that will match up well with my Amp I know most people dont like The sony brand but Its worked for me so far but here are the specs and model number SONY XM-D9001GTR CLASS-D CAR AMPLIFIER MONO SUB AMP ono subwoofer amplifier 550 watts RMS x 1 at 4 ohms (900 watts RMS x 1 at 2 ohms) 2-ohm stable Low-pass crossover (50-300 Hz, 12/24 dB/octave) Variable bass boost (0-10 dB at 40 Hz) MOSFET outputs and power supply Speaker-level inputs with high-level sensing Preamp inputs and outputs 4-gauge power and ground leads recommended - wiring and hardware not included with amplifier 15-13/16"W x 2-3/16"H x 10-13/16"D thanks for the help!!! |
Silver Member Username: Goodie_goopMidland, Texas U.S. Post Number: 634 Registered: Oct-06 | how many subs and whats your budget |
New member Username: Ballin_boi_03Post Number: 3 Registered: Jun-07 | 2 and i dont really have one I just dont want to break my bank or anything |
Gold Member Username: The_image_dynamicSan Diego Post Number: 1747 Registered: Dec-06 | Two Fi SSD's dual 2 ohm would work ok with that amp for $378 shipped. |
New member Username: Ballin_boi_03Post Number: 4 Registered: Jun-07 | thanks alot do u have any more suggestions |
Silver Member Username: Dakangofkrunk16Post Number: 511 Registered: May-07 | Get a better amp |
Silver Member Username: Dakangofkrunk16Post Number: 512 Registered: May-07 | Kicker 06ZX1500.1 Would be very nice on them 2 Fi SSD's and it will be able to be loaded with@ Fi SSD's Dual 2... Just a suggestion.. I would neva hook up any crappy amps, like sony, to very nice subs..you neva know what could happen man http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=17085 468 usd |
Silver Member Username: Dakangofkrunk16Post Number: 513 Registered: May-07 | Edit @ = 2 |
Gold Member Username: HdubbFarmington, Nm Usa Post Number: 2081 Registered: Nov-04 | i would think that the kicker compvrs would match up well, or the alpine type r or the rf p3. and if you can get them maybe the adire audio tempest, or the re se. i have not heard any of these new brands ike fi or rd or anything like that so i cant tell you anything about them. buy i like the comp vrs and the tempest and the se. it is your choice. |
