2ohms compared to 4ohms? help
Username: Spivey17323
Dunellen, New jersey United states
Post Number: 90
i have an alpine type r subwoofer... will bridging the amp to 600 watts x 4ohms sound better or 400 watts x 2 ohms sound better. can the sub handle 600 watts at 4ohms? sorry if its a dumb question but im new to this
Username: Dakangofkrunk16
Post Number: 479
Depends on the Voice Coil
Dual 2ohm VC which it would say 2ohm + 2ohm = 1 and 4 ohm stable....This will be the 4ohm stable
Dual 4ohm VC Which would say 4ohm + 4ohm = 2 and 8 ohm stable....This would obviously be the 2ohm load
Post Number: 480
I© thats the symbol
Username: The_image_dynamic
San Diego
Post Number: 1725
Josh you have those amp ratings all wrong... what is the make and model?
Post Number: 93
hmmm still confused... i think my type r is the swr 1042d... and its 4ohms dual voice coils or somethin... it should be able to take 600 watts by 4ohms right?
Post Number: 94
well alpine mrp m450... and the sub i have is the alpine swr 1042 d...
San Diego
Post Number: 1726
With the 1042 you will want to wire it to 2 ohms like this. You can't get a 4 ohm load from a dual 4.
Post Number: 95
ooooooooo ok thanx man
San Diego
Post Number: 1727
The m450 will put out 200 to each coil at 4 ohms. That would work ok. Disregard the above diagram and run one channel to each voice coil.
Post Number: 483
That would be left Channel Pos Neg to Pos Neg on sub and same for other side and Right Channel
San Diego
Post Number: 1728
No. It would be the + of channel one and the - of channel two to one coil. Then the + of channel three and the - of channel 4 to the other coil.
Post Number: 487
That is what i was tryin to say...But it is hard to understand...i guess...You explained it better tho
It is like your one sub is two subs in away, the way you load it that is..one VC is one sub the other VC is the other its easy
Post Number: 96
oooo ok thanks guys... hope this s*** thumps hard. one 10 type r and that m450 will sound pretty good i think. good for a first system??? opinions please
Username: Johnfiac
A-ToWn, Kingkong ain... I got Chuck ...
Post Number: 3096
From that question i dont think you understand ohms correct. The sub will take the power at ANY ohm, its just easier to supply more power at lower ohms, but if you can supply it at a higher ohm its always better because higher ohm = less thd although most of the cases its non audible
Post Number: 97
ooo i see
