My First box
Username: Salmiery
Martinsburg, WV
Post Number: 29
Hey - I will post pics.. but the circular saw was a little dull and there is maybe a half inch space between the boards in one part of my box - the rest is good.. silicon should seal that fine right?
Username: 350zspl
Delray beach , Florida Usa
Post Number: 44
1/2" is to much to seal with caulk or silicine
TAKE A pic of the seems so i can see what you mean
i would cut a brace an seem it with that but need to see to know for sure
pic and post
Username: Salmiery
Martinsburg, WV
Post Number: 30
as you can see.. it is sealed( left) all the way up until the end of the cut... (right)
A pic is worth 1000 posts!!
Post Number: 7237
I'm not sure what I'm seeing here. On the right, where the silicon is at its' widest. Is that the gap you're talking about??
Post Number: 7238
If it is I would suggest cutting another piece and screw and glue into the corner to cover that canyon.
Username: Salmiery
Martinsburg, WV
Post Number: 31
no that was just the wood glue.. i filled it with some silicon and it filled pretty good... I'll see what happens after everything is said and done.. it really wasnt that big after the glue dried
