Not sql, not spl, just beautiful sq?
Username: Charlesbhs
Post Number: 51
I was thinking of getting the elite 12" or Q 12" but are there any better 12" subwoofers or maybe even a 10" sq subwoofer? i just want pure quality.
Username: Ctmike
Ct.
Post Number: 4620
what's your budget for "pure quality"?
Post Number: 52
anything. i just want really nice sounding subs.
Post Number: 56
Like i asked this question a very long time ago and no one helped me out before. i dont really have a budget. so any amount of money is ok right now.
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 12406
Idmax
Username: Ctmike
Ct.
Post Number: 4621
exactly^^ imo best overall sub made. extremely nice sq with great output.
Username: Van_man
Boston South, MA
Post Number: 2524
jl w6 comes to mind.. TC sounds, Adire
Post Number: 57
what amp would be good to power the id max?
Post Number: 12408
JL 1000/1
Username: Ctmike
Ct.
Post Number: 4625
for one? what's the budget, there's alot out.
kicker 750.1
ed nine.1
sundown sae 1000d
arc audio fd 1200.1
mmats d800.1 (or 2, depending on vc), d1100.1
crossfire vr1000d
many others.
Post Number: 58
haha yea.. um anything a bit cheaper that amp can be pretty expensive...
Username: Ctmike
Ct.
Post Number: 4626
why not post a budget then. posting amps can go on for awhile.
Username: Nd4spd18
Southeast PA
Post Number: 2980
JL W6
SI Mag
Username: Skibum12189
Cleveland
Post Number: 671
well answer the question please....how much money do you have right now that you can spend on wires, amp, and sub(s) bc if you say you don't have a damn budget someones gonna suggest a 3000+ dollar system....even if its ballpark, anything helps dude
Username: 04redmach1
Columbus, GA USA
Post Number: 901
Can you fit a 15? If so, the SI MAG will be VERY nice with a 1000 rms :-)
As for Adire, STAY AWAY! VERY bad, well the newer models anyways.
Kevin
Username: Cenus
Hicksville, Ohio
Post Number: 3240
"As for Adire, STAY AWAY! VERY bad, well the newer models anyways."
haha funny but very true plus dan's a douche but i would go with a DD 9112 i hear they are very nice sq subs with some pretty good output, or maybe an AA atlas i have 3 and imo they are the best sq sub i've ever heared better than the w6 IMO but the spl isn't very good from them.
Username: Insearchofbass
Post Number: 5243
best ive listened to with decent output sq wise was a jl w6 v2 12 the only other sub that comes to mind would be a focal 11 inch it was very tight but not alot of output
http://cgi.ebay.com/Focal-Access-27A-11-Sub-1-Pair-Brand-New-Not-Refurbed_W0QQit emZ280121419197QQihZ018QQcategoryZ18805QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Post Number: 59
sorry had to wake up at 5:30 this monri9ng for work so i went to bed early and couldn't leave a budget. but anyways porbably around 2-400 for an amp and 1-350 for the sub. i know the mag 15" is like $500 but i dont think i could even fit it. is this better info? if you need more just ask.
Username: Th3pwn3r
Post Number:...
Post Number: 2960
Lol Charles.You went from no budget to 350 for a sub that's not much even for a single sub,for what you're looking for at least.
Post Number: 61
ok see thats why i need help. how much is a good sq sub? i knew that amount was gonna be way to low.
Username: Jkidder
Spring hill, Florida Usa
Post Number: 762
well to start it would be near impossible to find a DD 9112 for UNDER 650-700. that would be mah ideal single sub sq setup. if your saying no more than 500 go idmax, si mag, w6.
Username: M0nkeyman692
Post Number: 228
yo can the idmax really hit 10hz that is lower than any other sub ive seen
