Pioneer DEH-P7800MP inverted color issue?
Username: Mur
Hi.
Just got this new head unit. I like it a lot. However, if I use the level meter, analyzer, or gauges with tach, level and battery it seems to change colors intermittently.
Like a orange/white then back to it's normal setting. Like a negative image or something.
This is very annoying and I am not happy about it.
Has anyone encountered this on the OEL displays and if so, how can I stop this?
I thought it was a background issue, but no background to set with the level meters.
Changed from a prior Pioneer head. Used adapter for harness, soldered all my wires right before hook up and everything else works and displays right.
Any insight would be appreciated.
Thanks.
Username: Van_man
Boston South, MA
Post Number: 2493
Maybe a loose /bad connection on the face plate? Bad Unit? Try cleaning the contacts? Maybe a loss/drop in voltage for some reason?
Username: Mur
Well, I am going to take of face plate and reconnect.
Voltage seems very regular.
Otherwise I call Pioneer.
Thought I caught wind of something like this when surfing and searching,but nothing very clear as to the same issue or not.
Very hard to word it right and fine anything.
Username: Mur
Fixed.
Why they would create a setting that inverts the color every 30 seconds and is on by default, I will not understand.
In the manual it read to me at least, that if in a setting area and you didn't make changes within 30 secs it would revert, which I took as an exit.
Anyway, found while searching around.
Seems it is this way on a bunch of their OEL models, if not all.
Username: Adddisorder
West palm, Florida
Post Number: 4527
wow that is stupid now that i think about it my friend had that problem a few years back with i think a 680 or something.
