0phase box
Username: Jester_king
Post Number: 203
does anyone have any info on this type of box
Username: Oglejust
Post Number: 1804
never heard of it... got any pics or anything?
Post Number: 204
http://www.hexibase.com/gallery/main.php?g2_view=core.DownloadItem&g2_itemId=633 &g2_serialNumber=1
that is a phase box
Post Number: 206
bump
Username: Jblanford
Post Number: 1255
no one hear is going to know much about that design...you need to talk to the guys at team toxic bass, but they probably won't give you much info on it.
it does look like a T-Line though
Username: Jblanford
Post Number: 1258
here*
Username: Oglejust
Post Number: 1807
yeah i think ive seen that b4 but i have no idea how to calculate 1
Username: Jblanford
Post Number: 1261
^^^ no you wouldn't n000b
Username: Oglejust
Post Number: 1809
right....
Username: Jblanford
Post Number: 1262
go to bed fagbag
Username: Oglejust
Post Number: 1812
stfu asshat
Username: Oglejust
Post Number: 1814
Username: The_image_dynamic
San Diego
Post Number: 1630
Awwwwww -- you two will hump and make up next time you get together for your version of "White Boys Can't Jump" Upload
Username: Jblanford
Post Number: 1275
ogle humps fat girls FYI
San Diego
Post Number: 1631
LMAO Joe. He goes "hoggin".
By the way a zero-phase sub box is basically one that has damping on every curve and wall of the transmission line so that when the rear-wave energy (which causes cancellation and phase distortion) gets back to the rear surface of the cone, it is at such a low level that it has little to no affect on the cone behavior.... hence the name zero-phase. That's as simple as I can explain it, so if you still don't understand, go back to school ya retards
Post Number: 209
ok thanks for the info ^^, I'm not sure i understand it all the way but I wil just have to re-read it a few times, thank you
Username: M0nkeyman692
Post Number: 221
so it pretty much adds sq to a setup?
Username: Safe_cracker
Chicago, IL US
Post Number: 2924
Actually if you look at that pic it matches the phase of the rear energy wave to the front, minimizing or eliminating phase cancellation. Problem is that it is designed for low level systems and in order for it to work correctly in a high power, high stress situation, the box would need to be much thicker and heavier or some of the rear wave would begin to penetrate the back of the enclosure increasing cancellation. Polo..
Username: Big_edge_head
Milwaukee, Wisconsin USA
Post Number: 160
i think i saw that on toxicbass.com
