Need an amp
Username: Theweasel
Steamboat springs, Colorado U.S. of A
Post Number: 744
i need an amp that gives 1000-1500wrms at 1 ohm, and >2000wrms at 0.5ohm. try to keep it under 500
Username: Adam_s
Post Number: 1286
Sundown SAZ 1505d.
Username: Adam_s
Post Number: 1287
my bad 1500d^^
Username: Theweasel
Post Number: 745
is that stable at .5 ohm
Username: Ctmike
Ct.
Post Number: 4599
yes it is. even used to be warrantied at .5ohm. go thru kevin at low-hz.com, they have the best price you can get it for.
Username: Theweasel
Post Number: 746
i want to get one fi q, power it with a new amp, and then use that same amp for when i get another amp
Username: Theweasel
Post Number: 747
what is that amp's power rating at .5 ohm
Username: Adam_s
Post Number: 1288
Around 2000 if you have the electrical for it.
Username: Ctmike
Ct.
Post Number: 4601
http://www.soundsolutionsaudio.com/forum/index.php?s=91094df02238341b24ced2f9d9e 5b719&showtopic=7116
Username: Adam_s
Post Number: 1289
That gave 1890 with voltage dropping to 12.8 so if you could keep the voltage up you could see 2000.
