Bronze Member Username: MrwebbPost Number: 63 Registered: Dec-06 | I HAVE PURCHASED TWO OF THE PIONEER PREMIER COMPETITION SPL SERIES TS-W3002 SPL SUBWOOFERS AFTER HEARING THEM PERFORM AT A DISPLAY THAT PUT OUT A COMBINED 3000 WATTS AND 1000 WATTS RMS AND NEED TO KNOW WHAT AMP WILL BE A GOOD FIT? ALSO WHAT TYPE OF BOX WILL BE BEST FOR THESE SUBS? |
Silver Member Username: 04redmach1Columbus, GA USA Post Number: 875 Registered: Mar-06 | Are these subs DVC 4 ohm or 2 ohm? I may ave an amp that will work for you. What kind of budget are you working with? Kevin |
Bronze Member Username: MrwebbPost Number: 64 Registered: Dec-06 | they are dual voice coal 4ohm if im not mistaken...my budget is no more than$300 |
Gold Member Username: 420alldaylongPost Number: 1874 Registered: Sep-06 | chris webb The 3002 SPL are dual 2ohm. I heard two W3002 SPL on a Kicker ZX1000.1 and it sounded nice. What kind of vehicle do you have? |
Gold Member Username: 420alldaylongPost Number: 1875 Registered: Sep-06 | Two 12" |
Bronze Member Username: MrwebbPost Number: 66 Registered: Dec-06 | i am putting them in a 2000 ford crown victoria (big trunk) what kind of box works with them? yea they are 12" |
New member Username: TechmeMIAMI, FL USA Post Number: 10 Registered: May-07 | I HAVE BRAND NEW ROCKFORD FOSGATE PUNCH P1200.2 1200 WATTS PEAK POWER Response bandwidth: 20-20000 Hz Single-to-Noise Ratio: 80 dB Continuous Power: 300 Watts x 2 Amplifier Output: 2-Channel Input Single Voltage: 0.15-4V Crossover: Active crossover Crossover Slope: 12 dB/octave Low Pass Frequencies: 40-400 Hz High Pass Frequencies: 40-400 Hz Bass Boost Frequency: 45 Hz Bass Boost Gain: 0 to +18dB Output Power/ Total: 1200 Watt Amplifier Class: Class AB Amplifier Output: 300 Watt- 4 Ohm- 2 Channel(s) 600 Watt- 2 Ohm- 2 Channel(s) 1200 Watt- 4 Ohm- 1 Channel(s) 320 BUCKS 1 YEAR WARRANTY. |
Gold Member Username: CtmikeCt. Post Number: 4572 Registered: Feb-06 | get the fuc_k off the forum^^^. |
Silver Member Username: Koz1031Monticello, In United states Post Number: 434 Registered: Jul-04 | check this out, should do you just about right http://cgi.ebay.com/ORION-XTRPRO-2400-D-AMP-2600W-RMS-BEST-ORION-AMP-EVER_W0QQit emZ300117772394QQihZ020QQcategoryZ39732QQrdZ1QQcmdZViewItem |
Bronze Member Username: MrwebbPost Number: 67 Registered: Dec-06 | any ideas as far as a box is concerned? do i need to go big? |
